About 2 weeks ago when i would go to start my truck turn the key to the start position and it would delay for a few seconds and then turn over and start no problem (mostly in the morning when it was a bit cooler) Afternoons it never did it. Always ran perfect after it started and as long as it started it never gave me the issue again for the day. Even if it was still cooler outside.
Then this morning I get in it and try to start it and it wont crank at all. As soon as i turn the key to the start position the doors unlock.
I like to check and see if the starter relay is getting the signal to crank before I do anything else. After that, I would like to check the starter and then the battery cable.
