Hpop problem
Old Aug 22, 2011 | 05:22 PM
bad12jr's Avatar
bad12jr
Yep for the most part. It had a slight miss. No power on bottom end but once it got up on the charger it didn't run to bad.
Old Aug 23, 2011 | 07:12 AM
Talyn's Avatar
Talyn
Originally Posted by Ctkallday666
It would struggle butnpull through right? Then when you stop it would sound like its gonna die?
Sounds like you should check the IPR O-rings.
Old Aug 23, 2011 | 08:54 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Sorry i got back so late. But i cleaned the screen. The q-tips came out clean no dirt or anything. And plus iam getting 55 -56 psi of fuel. I had the mechanical fuel pump replace about 2 mounths ago.
How did you clean the screen? with the cotton in the q-tip or without it? and did you checked with a mirror the CLEAN screen?
Your oil with 2000 miles should be fine.
Eddie C
74
May 12, 2016 06:20 PM
Redneckmorton
Apr 29, 2013 10:38 PM
fordtruck661
Jun 18, 2012 05:41 PM
terrapin88
Mar 27, 2011 10:51 PM
Never Done
13
Nov 9, 2004 11:18 PM
