Under the hood
Old Aug 20, 2011 | 04:15 PM
timmyboy76's Avatar
timmyboy76
Under the hood
Its been a few months since i replaced the turbo, and checked things out. Removed the intake hose and no dustong going on. I want to remove the valve covers and fire truck up. What am i looking for, oil discharge is good, too much is bad or nothing is bad/good. Also, is it possible to disconnect the #8 cylinder injector to find source of ticking/bad injector, will it cause a problem doing that...thanks again
Old Aug 20, 2011 | 09:00 PM
F350-6's Avatar
F350-6
You can unplug an injector and let the motor run. It will have a miss and throw a CEL, but it will run fine, so yes you can disable #8. Keep in mind that the injector wiring carries a lot of voltage in it. Many people have unplugged the injectors one at a time with the engine running, but doing so carries a risk.
Old Aug 20, 2011 | 09:02 PM
twags6's Avatar
twags6
120 volts DC isn't fun. You should be able to unplug it while the engine is off and then restart it.
Old Aug 20, 2011 | 11:15 PM
clintbonnie's Avatar
clintbonnie
Do the 50 cent fix while you have the covers off..and re-torque everything..
ExPACamper
Aug 15, 2018 08:25 AM
Alta
Dec 1, 2013 05:19 PM
simms63ss
Apr 26, 2011 06:32 PM
Bustaduck
Nov 7, 2010 09:37 PM
70spoiler
Mar 13, 2004 09:43 PM
