could it be a bad injector
Old Nov 4, 2010 | 07:07 PM
Bustaduck's Avatar
Bustaduck
been having cold start issues so I checked my ficm it checked out fine. been noticing the smell of diesel under the hood so no biggy I got under the hood to see if I could find a leak but there is nothing it is as clean as could be. so any way while I was under there decided to check the fluides and when I pulled the dip stick it was over full and smelled like diesel fuel any ideas could a bad injector cause this are what?
Old Nov 4, 2010 | 08:04 PM
cak301's Avatar
cak301
Sounds like it could be an injector sticking open. If so I wouldnt even start it let alone drive it anywhere. You run the risk of burning a hole in the piston.
Old Nov 6, 2010 | 01:53 PM
firefighter317's Avatar
firefighter317
the 6.0L have problems with the injector o-rings and causing the oil to be diluted with diesel fuel, overfilling the crankcase. If im not mistaken, there is a recall on some models. Not sure if its on yours or not, but its worth checking into. Odds are either the o-rings are bad or the injector body is cracked. If I were you, I'd go ahead and pull the valve covers off and check all the injectors. They arent too hard to change out. I'd pull them out and check all the o-rings. If the o-rings are torn, I'd replace all o-rings and the copper washer. Be sure and use only hand tools to reinstall the injectors. Using air tools will damage the injectors/injector o-rings. As mentioned above, dont drive it. Its overfilling the crankcase and will cause premature seal failure due to excess oil pressure.
Old Nov 6, 2010 | 03:21 PM
bismic's Avatar
bismic
Almost certainly an injector, but I am not aware of any recall for the issue.
Old Nov 6, 2010 | 05:06 PM
cheezit's Avatar
cheezit
no recalls for it
Old Nov 6, 2010 | 09:55 PM
firefighter317
there is a recall. i was mistaken on the engine. Its on the 6.4L. Recall# 09B08S1. States they have premature injector o-ring wear and requires replacement of updated injectors. But yes you have an injector problem as mentioned above.
Old Nov 6, 2010 | 09:57 PM
cheezit's Avatar
cheezit
09b08 goes by vin only and is very limited. not all trucks got/get new injectors and very few get all 8
Old Nov 7, 2010 | 06:28 PM
Bustaduck's Avatar
Bustaduck
thanks for all the help going to work on it this week maybe allwill go well. I will post to let yall know what I find
Old Nov 7, 2010 | 09:37 PM
firefighter317
thats true cheezit but all i said was there was a recall. didnt say it was for all/most vehicles.
allhuntalltime
Mar 6, 2013 05:12 PM
hasteranger
Oct 11, 2011 08:23 PM
hasteranger
Oct 4, 2011 07:58 PM
new2diesel
15
Jan 7, 2010 03:37 PM
dburke8088
Dec 3, 2006 07:14 PM
