Help with C6 Tarans problem
Old Aug 20, 2011 | 04:07 PM
DDennis's Avatar
DDennis
I'm hoping someone may understand my babble. I have a 1988 F150 4x4 5.8 x-cab stock except the 31's. My issue started when I had a local shop replace the oil pump. Not sure what got bumped out of wack but has not shifted right sence. Here is what it is doing. It will not shift auto on it's own and seems like not getting all the gears I have to let up off the gas pedal for it to shift or it will stay in first. Park would not lock in but adjusting the linkage got it close enough to drive which I have been for awhile. I bought a 88 Bronco that a kid rolled for his momma(bet she was happy) to cheap to pass up for the trans. I got around to driving my F150 up on small ramps puts it close to 15 or 20* incline and started looking. Reading the posts I could find most pointed to vacum issue so I pulled the vacum line off the pod on the pass side rear of trans and trans fluid started pouring out. Within the last 6 months I had the trans flushed and level checked several times....any ideas or more info needed?
Thanks
Old Aug 20, 2011 | 09:06 PM
husker's Avatar
husker
The line to the pod on the back is to the modulator and could cause some of the problems you describe. Also it shouldn't leak a bunch of fluid. I would try replacing it if your linkage is adjusted ok.
Old Aug 21, 2011 | 02:50 AM
Flip4ford's Avatar
Flip4ford
I agree with Del try replacing the modulator!
cpettymore7777
Sep 11, 2009 05:21 PM
tjwc1
Jan 24, 2009 04:45 PM
bomberboat
Oct 27, 2008 01:45 PM
80F250cust
Nov 12, 2007 01:04 PM
joeytoad83
Aug 17, 2004 07:56 PM
