trans?????
Old Aug 14, 2004 | 07:43 PM
joeytoad83's Avatar
joeytoad83
trans?????
one of my friends just got a 88 f150 with a l6 and a c6 trans the question is when you put it in 1 or 2 its fine and shifts but when you put it in drive it goes back to first and wont shift up, the modulator has already been replaced. any ideas as to what it could be
Old Aug 15, 2004 | 04:35 PM
rclarke's Avatar
rclarke
check for manifold vacumn to the modulator
Old Aug 17, 2004 | 03:59 PM
SgtJoe's Avatar
SgtJoe
rclarke listed the best first check. If that isn't it, check the governor. If it is stuck, it will do the same thing. Better to replace than fix. Good luck.
Old Aug 17, 2004 | 07:56 PM
rclarke's Avatar
rclarke
Thats right, a stuck governor can also prevent upshifts. But if a governor is stuck, the only thing I have found that will stick a governor is trash in the oil. Trash in the oil usually indicates a transmission failure already or very soon. Possibly an overhaul in the near future.
