Here's some more for you. I could give you the build month, but that book is out in the garage and it's too late to be going out there. Sorry! Anyway, F10 = F100, two wheel drive pick-up. C = 292 CI, 2 bbl V8 engine. L = built at Michigan Truck Plant. WB 128 is your wheelbase in inches. Color A = Raven Black as 5star mentioned. Model F101 = 2 wheel drive, 4200 GVW. E = your interior trim code: red crush vinyl and red check stripe woven plastic. 81 = 81B Custom Cab. As 5star said, Trans A = Ford 3 speed manual transmission, and Axle 12 = Ford non-limited slip 3.89 axle. Maximum Gross Vehicle Weight = 4200 pounds. NET vehicle horsepower = 135 at 3800 rpms. The District Sales Office to which this vehicle was assigned (21) was Atlanta and it was not special ordered.
It's F10 = F100 two wheel drive...and...that's it.
The series code F10 does not decode to a pickup until 1973.
Prior to 1973, an F10 could be a Pickup, or a Cab & Chassis, or w/a factory installed Flatbed or Stake Bed. Or one of two Open Drive-Away's: Chassis & Windshield or Chassis & Cowl.
No F100/350 series code prior to 1973 decodes to what "back of cab" equipment a truck came with.
553635 = 1964, assembled June 1964.
Trans A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
