VIN decode please
Old Sep 10, 2009 | 10:52 PM
Shorty 66's Avatar
Shorty 66
VIN decode please
A new truck I just got. I will get pics up later. I think it is a interesting truck.
Vin-F10YL733446
WB-115
Color-M
Model-F100
Body-E81
Trans-C
Axle-17
GVW-5000
HP-172 @ 4000
DSO-63
Thanks
Old Sep 11, 2009 | 09:58 AM
dusty64f100's Avatar
dusty64f100
Vin-F10YL733446
F10 -2 Wheel Drive F-100 5000 G.V.W.
Y- 66 352 2V 208hp @4400
L - Michigan Assembly Plant
733446 - Aug 1965
WB-115 - SWB obviously
Color-M - Wimbledon White in 65/66 only (61-64 used corinthian)
Model-F100 - 2wd 5000 G.V.W.
Body-E81 - Specific to seats and trim level, probably cc (Possibly Red crush vinyl and red check strip woven plastic but that's for a 64 and might've changed)
Trans-C - for 66 was 3 spd Manual Light Duty
Axle-17 - 3:25 ratio
GVW-5000 - typical f100
HP-172 @ 4000 - most likely whp, 208 at crank
DSO-63 - District in which the truck was ordered - Memphis, Tennessee. Arkansas, Western Tennessee and Northern Mississippi
That about what you hoped for??
Old Sep 11, 2009 | 09:51 PM
Shorty 66's Avatar
Shorty 66
The guy I got it from pulled a 3 speed o/d out and put in a regular 3 speed. Is there a different code for a 3 speed o/d tranny on the data plate?
Old Sep 12, 2009 | 03:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Shorty 66
Body-E81
Trans-C
Axle-17
GVW-5000
HP-172 @ 4000
DSO-63
E81: E = Red Crush Vinyl & Red Cody Pattern Woven Plastic // 81 = 81B Custom Cab.
C = Ford Type 3.03 3 Speed Manual all Syncromesh Transmission.
17 = Ford 9" Rear Axle / 3.25-1 / non Limited Slip / 3,300 lb Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM.
63 = Memphis TN Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
If the truck had originally come with the Borg Warner T-85 3 Speed Overdrive, the TRANS code would have been B
1963 was the last year for Corinthian White. 1964 was the first year for Wimbledon White.
The Ford Type 3.03 3 Speed Manual was introduced in 1963, used thru 1986.
208 is the Gross HP. The air cleaner had a decal with this HP figure.
Burlcojoe
Jun 8, 2014 08:31 PM
dbgphx
Aug 15, 2013 04:40 AM
Itsme7
Jan 3, 2011 09:22 PM
Catsailor
Apr 14, 2008 07:39 PM
SportCustomWalt
Jun 1, 2007 06:41 AM
