how much pressure?
Old Aug 17, 2011 | 11:17 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by PaysonPSD
I think you have a leak Trey. The gauge is on ZERO.
From another thread: Do you have the part numbers for the '05 front bumper brackets?
No air was going in. And no I do not.
Old Aug 18, 2011 | 06:11 AM
429 f-100's Avatar
429 f-100
From another thread: Do you have the part numbers for the '05 front bumper brackets?[/QUOTE]
robin which ones there are three per side the one on the end of the rail is 5c3z17b984aa and 985aa // the straight one is 5c3z17754aa and 7755aa //
the other one i bought but did not use when i put my bumper on. they go on the outside of the rail to the end you could use them but needed some fab i guess the frame is a little different i haven't used them yet and the 99 didn't have them . those are 5c3z17b750aa and 749aa .
Old Aug 18, 2011 | 09:44 AM
bama29fan's Avatar
bama29fan
Originally Posted by bama29fan
great video bulla!!!
mine wont go anywhere near that....like i said....about 8lbs max and thats with me sticking my finger in the ccv tube hole. when i remove my thumb you can hear the air release. same thing with the oil fill tube....remove cap and you can hear the air escaping.
i have flipped the oil cap over and it stays on and doesnt seem to have any excesive blowby.
what could be my issue?
anyone have any thoughts on this??? am i trying to make something out of nothing?
Old Aug 18, 2011 | 11:21 AM
bulla's Avatar
bulla
It makes no sense for air to be coming out thecrankcase. Unless the ccv is hooked up but you said it wasn't. Only other place would be by the rings and if that was happening your truck wouldn't run very good if at all. Do I have this right? You are pressuring up the intake and are getting air through the base.
Old Aug 18, 2011 | 11:36 AM
timmyboy76's Avatar
timmyboy76
bama, hook everything back up, and fire up motor, with it running, remove the cap and lay it upside down. Post back if its popping/not popping off
Old Aug 18, 2011 | 11:38 AM
bama29fan's Avatar
bama29fan
correct...air going in thru the turbo inlet and i can hear air coming out of the ccv and oil fill tube. but the kicker is the truck doesnt seem to be running bad....25psi at WOT, no smoke (of any color) and get 16mpg around town. there is some noise that i hear under light acceleration that sounds like an exhuast leak...kind of a kachu kachu kachu sound that goes away when i let off the throttle....sometimes sounds like its exhaust leak sometimes sounds like injectors?
Old Aug 18, 2011 | 11:39 AM
bama29fan's Avatar
bama29fan
it will stay on top...doesnt pop or bounce.
Old Aug 23, 2011 | 07:12 PM
bama29fan's Avatar
bama29fan
maybe some new info???
I checked the dip stick tonight and there were bubbles on the last inch of the tip. What are all the causes of aireation and which would be the most likely.
Old Aug 23, 2011 | 08:17 PM
hotroddsl's Avatar
hotroddsl
Originally Posted by bulla
I've tested mine and it's all sealed up but, it takes quite a bit of air for ot to actually pressure up and it's not going to hold pressure. It will leak through the valves and eventually out the exaust. And just a word of advice, I wouldn't go above 15-20 lbs. If your tester slips out, it will be a rocket and possibly cause casualties! Yea ask me how I know!!
Ok ....how do you know.....
Jim...& frisky fat Monty
bigreentruck
Apr 19, 2015 07:03 AM
Jake_f16
Nov 20, 2012 12:58 PM
SLAMMIN 22
19
May 17, 2010 08:03 AM
60RatRod
17
May 6, 2010 02:20 PM
carlsson
May 15, 2008 05:20 PM
