COOLANT DISAPPEARING
Old Aug 17, 2011 | 02:21 PM
blieux1's Avatar
blieux1
OK SO I HAVE SEARCHED THIS FORUM ON THIS SUBJECT BUT NO REAL HELP. I HAVE PUT 5 GAL OF ANTIFREEZE IN TRUCK OVER THE PAST COUPLE DAYS. NO SIGN OF NONE LEAKING. NOTHING SHOWING IN OIL. I JUST DONT KNOW. SOMETIMES YOU CAN SMELL IT OUTSIDE OF TRUCK. ANY IDEAS.
Old Aug 17, 2011 | 02:25 PM
clem1226's Avatar
clem1226
is it smoking white? 5gal in 3 days is a lot!!!
Does the cooling system hold pressure?
Old Aug 17, 2011 | 02:33 PM
Pitcrw6's Avatar
Pitcrw6
5 gal is way alot. I would triple ck too make sure its not in your oil. If its not in your oil then its getting mixed in with your fuel. You might have an injector cup or cups thats leaking. Does your coolant smell like diesel fuel?
Old Aug 17, 2011 | 03:14 PM
bulla's Avatar
bulla
But if that was the case it would be filling the coolant as opposed to emptying it. When injector cups cause problems it's always fuel in coolant, not coolant in fuel because of the higher operating pressure of the fuel system. Hope this helps.
Old Aug 17, 2011 | 03:18 PM
bulla's Avatar
bulla
To the op, if you can smell it outside than there is a leak or an overflow issue. Not sure how common it is but make sure your heater core is not leaking, but I think that would be obvious.
Old Aug 17, 2011 | 03:22 PM
clem1226's Avatar
clem1226
I was thinking cracked degas tank that is leaking on to the fan under pressure and evaporating............................
if that is the case a cooling system pressure test would tell the tale.
Old Aug 17, 2011 | 04:49 PM
blieux1's Avatar
blieux1
Ok system hold pressure fine and no white smoke. No water in oil at all and nothing in the coolant.
Old Aug 17, 2011 | 06:24 PM
1996pwrstrk's Avatar
1996pwrstrk
Is this truck completely stock ,what mods do you have ? Have you done any work to it recently?
Old Aug 17, 2011 | 06:42 PM
4EXTRDR's Avatar
4EXTRDR
So your oil level isn't moving up, no white smoke and ( obviously) their isn't anything leaking...how long did you watch for a pressure drop on the coolant system and how much pressure? it has to be going somewhere....subscribed, this is an interesting one w/ that much coolant loss.
Old Aug 17, 2011 | 11:12 PM
blieux1's Avatar
blieux1
Only mod is programmer and its been on it for 5 years. No work recently. Every time i open tank to add its pressured up. Yes this is interesting .
Old Aug 17, 2011 | 11:35 PM
timmyboy76's Avatar
timmyboy76
you pull the trans dipstick yet? Why not, its hiding somewhere
Old Aug 18, 2011 | 06:04 AM
4EXTRDR's Avatar
4EXTRDR
ok, you are reading preessure from the cap itself...I would get my hands on a pressure tester and pump it to maybe 15lbs and see if that holds good...a blown headgasket can pressurize the coolant too from the exhaust pressure.
Old Aug 18, 2011 | 02:16 PM
blieux1's Avatar
blieux1
yes pulled the tranny dip stick. ok i will get a tester and check it that way.
Old Aug 18, 2011 | 06:15 PM
Pitcrw6's Avatar
Pitcrw6
Is your tailpipe wet?
Excursion Gary
16
Aug 22, 2020 05:06 PM
bunklash
Apr 10, 2019 07:39 PM
hydro man 17
Mar 18, 2016 07:45 AM
diamondjranch
15
Jun 1, 2012 03:04 PM
mortarmagotjoe
Jan 4, 2011 01:14 PM
