e4od valve body
Old Aug 17, 2011 | 01:49 PM
pjenk's Avatar
pjenk
e4od valve body
I swaped the vale body from a good e4od two wheel drive and now the truck dose not seem to have first gear.All others ok is it possible i did not put all the small litte ***** in there proper location?The problem ended up to be the vss.I was wondering if there was a scmetic of where the ***** go before I swap it back.7.3 IDI f250 4wheel drive.Used to burn rubber in first not any more.
Old Aug 17, 2011 | 02:36 PM
Marianna2003's Avatar
Marianna2003
Welcome to FTE. Are you sure the original didn't have a shift kit installed. I bought a "Tugger" kit for my '93. While installing it, I realized that it had the same springs I was installing.
Go to this link for a schmatic of the ball positions:
E4ODBallPositions.jpg picture by Marianna2003 - Photobucket
Old Aug 17, 2011 | 07:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
i got one too:
https://www.ford-trucks.com/forums/8...our-*****.html
Old Aug 18, 2011 | 09:38 PM
pjenk's Avatar
pjenk
Thank You! I am also looking for the pin and cavity location/wiring for the trany ecu.My tach quit today and the OD light is luminated 2nd and forth gear only.I ohmed the sensor after replacing it 64.97$ wirng good to first connector by battery but the harness runs around the front of the radiator to the trans ecu/left kick panel.
Old Aug 23, 2011 | 03:59 PM
pjenk's Avatar
pjenk
Thanks I found the power relay to the tcm at 4.7 volts.
Mikemusial
Sep 17, 2014 09:43 PM
FordYoungGun35
Jan 17, 2013 09:46 PM
Eicca
Aug 1, 2011 11:03 AM
pro70golfer14
Oct 12, 2009 07:01 PM
RyanJake
Mar 23, 2007 04:14 PM
