Okay check it out my factory gears of 3.55 ratio went BOOM! what
do you guys think I should replace with? The same,4.10 or other?
heres the mods:
86 ford 150 5.0 4x4 EFI
Ebrock heads-
wolverine cam
long tube jet hots headers
Aod w shift kit
32-1150-15 BFG's
I agree with Brian 100%. You might actually get better mileage with the 4.10 gears as that little 302 has had some serious soup up work done. It might not operate efficiently at lower RPMs. 4.10 gears might put it in the sweet spot.
also, if your planning on lifting your rig and running 35's soon you might concider 456 gears, i know thats a little step now with you running 32's but if your setup does change you dont want to go back through them again. and with that aod it wouldnt be to undrivable.
just a thought. im just one for doing **** once. becaue a gear swap is not cheap
