97 E4OD
Old Aug 13, 2011 | 08:16 PM
fordpride's Avatar
fordpride
97 E4OD
I got a 97 F-250 with a E4OD and I got a over temp code today my trans has never gone above 190 what temP does that code set at or is there something that can go wrong and set that code
Old Aug 14, 2011 | 06:55 AM
projectSHO89's Avatar
projectSHO89
Post the actual fault code.
Old Aug 14, 2011 | 07:58 AM
fordpride's Avatar
fordpride
P1783..........
Old Aug 14, 2011 | 09:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That code means the TFT (Transmission Fluid Temperature) sensor read over 270°F. If the trans didn't really get that hot it means the sensor is starting to fail. As long as you have a gauge I'd ignore this until it does it more often. For now clear the code and see if it comes back.
Old Aug 14, 2011 | 10:56 AM
fordpride's Avatar
fordpride
Mark I have a gauge and a scangauge and they both are within 2-3* of each other. Where is the temp sensor at? Is there anyway to teat it?
Old Aug 14, 2011 | 01:02 PM
Mark Kovalsky
The sensor is inside the pan. The best way to test it is to watch what it's reading on the Scangauge.
Est1991
Aug 23, 2023 12:20 PM
mrrish79
16
Nov 21, 2013 08:28 AM
IABill
Jul 16, 2010 12:31 AM
fballer985
Nov 7, 2007 01:37 PM
jwdenney2
Apr 14, 2003 01:32 AM
