well to make a long story short... the transmission code is u but when i took it in since teh od light was flashing the code i got was a 628. being as 628 is a tc slippage for an e4od do i have an e4od or a 4r70w? btw its a 95 f150 302 if that helps and temp gauge was nearly redline
Code 628 = Converter clutch Lock-Up error (E4OD) [most likely resulting in TC slippage like you said]
I would just assume that the code is used by all the electronic transmissions of this era, and not just the E4OD. You can confirm which trans you have using this chart:
