Help with pilot bearing
Old Aug 13, 2011 | 04:29 PM
bard6943's Avatar
bard6943
Unhappy Help with pilot bearing
I have a 92 Ford Ranger, 5 speed, with a double 4 engine. Here is my problem... I have dropped the driveshaft, transmission, clutch and flywheel. My pilot bearing had completely blown up in the whole thing. The problem is that it left the outer core stuck in the crankshaft. How do I remove it. Tried the pullers with no luck. Last option is to find someone with a Dremel and try to remove it that way. But it seems to have welded itself to the crankshaft. Is there anyway to remove it without having to replace the crankshaft? I am desperate considering this is my only vehicle and I really need it to get back and forth to work...
Old Oct 11, 2011 | 10:04 PM
wcbarker's Avatar
wcbarker
Use dremel tool carefully
Old Oct 12, 2011 | 08:01 AM
wp120470's Avatar
wp120470
The best sucess I have found at work is to mig weld a bolt to it very carefully and use a slide hammer on the bolt. Always keep plenty of water available to keep the heat from getting too hot. you dont want to heat the crank too much. good luck.
hotroddually
Jan 1, 2009 09:31 PM
ech0sh4y
Jan 31, 2008 11:35 PM
Flaflathead
Apr 4, 2005 08:48 PM
wycowboy
May 5, 2004 10:03 PM
duback66
May 5, 2004 02:53 PM
