Replacing pilot bearing.
Old Apr 27, 2004 | 01:34 PM
duback66's Avatar
duback66
I removed my tranny and noticed that the bearing inside the flywheel at the rear of the crank is in pieces. How is this thing replaced? Do I have to remove the flywheel to replace it?
Old Apr 27, 2004 | 03:42 PM
duback66's Avatar
duback66
It's a 1989 f150 with a 4 speed and 300 6 cyl.
Old Apr 27, 2004 | 03:48 PM
King Triton's Avatar
King Triton
No you dont need to remove your flywheel,although if you are changing your clutch because of wear,I would suggest having it resurfaced,but to remove your pilot bearing,pack the hole with grease,then use a rod or punch that just barely fits in the center of the bearing,put a rag around the punch and smack it,the force of the grease behind the bearing will pop it out.
Old Apr 28, 2004 | 08:45 AM
duback66's Avatar
duback66
So the whole thing in the back of the flywheel comes out? About 2 inches across.
Old May 5, 2004 | 02:53 PM
Levergun's Avatar
Levergun
Yes, the entire bushing will pop out as Triton said!
