Pilot bearing HELP!!!
Old Apr 27, 2004 | 05:34 PM
wycowboy's Avatar
wycowboy
I'm instaling a new clutch but I cany get My pilot bearing out, How the h#ll do I do it. I've tryed pring it with all sorta of stuff, I put a bolt in the inside to grip it with no good, Ithik if I cant if i dont get any good Ideas from you all I 'l bee drillingit out. Thnaks J
Old Apr 27, 2004 | 05:46 PM
King Triton's Avatar
King Triton
I just replied to this in another post.Pack the hole with grease,then take a bolt,rod,or alignment tool that will slide in the bearing with as little amount of side clearence as possible,pack a rag around the tool and smack it with a hammer, the force of the grease will pop the bearing out.
Old Apr 27, 2004 | 10:03 PM
hreed's Avatar
hreed
Also, a little heat will help. Either a small propane torch, heat gun, or even a hair dryer.
Old Apr 27, 2004 | 10:43 PM
wycowboy's Avatar
wycowboy
I'm I dont think the greas wil work it's in ther good puss I bugre it up, too much to make a seal
Old Apr 27, 2004 | 11:08 PM
King Triton
If you get a piece of rod that is a fairly snug fit,you will be amazed at what the pressure from the grease will do.Just pack a good amount in the hole.
Old Apr 28, 2004 | 10:27 AM
wycowboy's Avatar
wycowboy
Ill giveit a go, Thaks much
Old May 5, 2004 | 02:51 PM
Levergun's Avatar
Levergun
Yes, that is the answer. Taht is how I got mine out as well. Pack that baby full of grease and then take a dowel or bolt or socket and pound on it. Thr pressure will push it right out! It works well because it is even pressure all across the entire surface!
Old May 5, 2004 | 08:49 PM
85e150's Avatar
85e150
I did this on a 289--got a bolt that would thread into the bronze pilot bushing. Once the threads bit, I was able to lever it out. Not sure it will work with the larger item you are working on.
Old May 5, 2004 | 10:03 PM
F 2fifter with a 4 sixter's Avatar
they do make a pilot bearing puller as well ive seen them advertised on autozone.com i had the same trouble with mine i ended up using a puller and putting all the flywheel bolts on to the crank putting one of the puller arms inside the bearing so that it would grab on the other side to help pull it out then put the puller bolt face on each of the bolt heads and pulled on each side bolt to bolt till it came out worked good
fordka
Jun 8, 2014 04:04 PM
1988F-150
Sep 26, 2009 06:42 PM
Wim Crone
Nov 15, 2005 10:32 AM
Franken-Truck
Aug 12, 2004 11:17 PM
88grandmarquis
Aug 6, 2004 04:19 PM
