460 overheating help
Old Aug 13, 2011 | 10:03 AM
johngeorge's Avatar
johngeorge
I have a 460 in a 86 F250. I recently installed a new timing chain and high flow water pump. Before doing this it ran at about 195 - 200 degrees. The chain was very worn out. We got it back together and it is now running hot (230 degrees). We set the initial timing at 6 deg BTDC. We pulled the vac hose off the dist diaphram and capped it. We didn't look at the total timing. It has a 180 thermostat that we have checked and ruled out. Could it be that the timing is off and causing it to run hot? If so: what should it be set at? Thanks for any and all advice.
Old Aug 13, 2011 | 10:29 AM
ctubutis's Avatar
ctubutis
The timing would need to be WAY off to affect the temperature to that degree, and there would be other signs telling you that something is wrong (wouldn't run well at all).
Given your description, I'd guess a water pump was installed with an impeller facing the "wrong" way as will happen when people install a pump intended for a Serpentine belt system onto an engine that uses V-belts.
They spin in opposite directions and the impellers accommodate that.
Guess it could be the thermostat is installed backwards, too, or maybe there's a lot of air in the system that needs to be burped out........
Old Aug 13, 2011 | 10:45 AM
Stangrcr1's Avatar
Stangrcr1
^What he said....
All excellent possibilities, especially when you say a new high flow water pump....
BTW, was the original thermostat 180 or 195?
Old Aug 13, 2011 | 10:47 AM
johngeorge's Avatar
johngeorge
I put the old pump back on and it still runs at 230. Could air in the system cause that big of a difference?
Old Aug 13, 2011 | 10:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There is no reverse rotation on the 7.5 serpentine routing.
See Illustration 5-45.
http://www.daycoproducts.com/daycoweb.nsf/cf652a4feb630ad0862571a4005ae40c/1120b6e8f406fd3e862574c000569a91/$FILE/SerpentineBeltRoutingGuide.pdf
Another possibility is a radiator restriction causing the lower hose to collapse with the rpm's up.
Do you know if the lower hose has a support spring in it?
Old Aug 13, 2011 | 10:53 AM
Stangrcr1's Avatar
Stangrcr1
Air does need to be burped out. Usually there is a small hole or notch in the thermostat disc that allows air to bleed past.
Old Aug 13, 2011 | 10:55 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Try drilling a tiny hole in the thermostat flange to allow it to purge the air.
If you start it with the radiator cap off can you see the flow across the top of the core once it reaches 180*?
Old Aug 13, 2011 | 10:58 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
8-10* of advance is correct.
http://www.flickr.com/photos/24183730@N03/2340584319/http://www.flickr.com/photos/24183730@N03/2340584319/ by http://www.flickr.com/people/24183730@N03/, on Flickr
Are you sure your balancer hasn't slipped?
Old Aug 13, 2011 | 11:18 AM
ctubutis's Avatar
ctubutis
Illustration 5-45
OK, I believe you - you have a 460 and I don't, that makes you more of an expert than me.
The impeller pointing the wrong way is just a possibility I was bringing up.
Another possibility I thought of is the installation of a new fan with the blades pointing the wrong way.
Old Aug 13, 2011 | 12:24 PM
cj06's Avatar
cj06
hows your radiator ? if the radiator is a small 1-2 core then the water pump may be pushing the water through to fast to cool ! did you do any thing else ? changed the fan , fan clutch ?
did you use a adjustable timing chain ? and if so is it set straight up or advanced or retarded ?
Old Aug 13, 2011 | 01:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I think all 460's got the three row radiator.
The timing is WAY off if it's set at 6 and the vacuum is disconnected.
With only centrifugal there's no way it could have enough advance at idle to burn the mixture correctly.
Old Aug 13, 2011 | 07:59 PM
F250HD Custom's Avatar
F250HD Custom
Vaccum advance is your friend, at idle and for mileage, to be sure. You do plug it to set timing (8-10 degrees is normal) and then you hook up the vaccum again!
Straight centrifical would only work for a race tuned distributor with a fixed "point plate", and the curve set to add back in the advance the vaccum is no longer providing. All engines need a certain amount of initial, and a curve. CC
Old Aug 13, 2011 | 08:02 PM
F250HD Custom
Timing chain off a tooth?? CC
Old Aug 14, 2011 | 01:04 AM
johngeorge's Avatar
johngeorge
Second time someonehas said that the dist might be off a tooth. It runs good and is set at 8 degrees BTDC. Could it be off a tooth and still have good performance and be able to set it at 8 - 10 degrees with a light?
Old Aug 14, 2011 | 01:07 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sure, if you have enough room to swing the vacuum advance can around instead of having it pointing straight forward.
If the timing chain is off a tooth moving the distributor is not going to fix the cam timing.
wacoustahonyock
13
Apr 18, 2020 04:00 AM
DKW 86
Dec 8, 2010 03:34 AM
68bluebeast
15
Mar 18, 2007 09:58 PM
detmerdj
Dec 14, 2006 03:04 AM
zimman20
Oct 9, 2002 12:39 AM
