timing chain
Old Mar 13, 2007 | 07:02 PM
68bluebeast's Avatar
68bluebeast
timing chain
I am having my timing chain replaced on my 68 and I was thinking about having a new water pump put on it while my mechanic has everything apart as I think it is the original pump. Is that a good idea? also anyone know of anything else I should have him do. The timing chain did not brake but it is noisy.
Old Mar 13, 2007 | 07:38 PM
Mil1ion's Avatar
Mil1ion
Good plan. Make sure you get a matching one if you have a fan clutch as the nose on them are 2 different sizes
Old Mar 13, 2007 | 08:59 PM
Fordteamone's Avatar
Fordteamone
68bluebeast when this has been done on a number of my Fords I like to replace the water pump, v-belts, hoses and thermostat. I used to work in a service station and it seemed like when you tried to get by on the cheap a hose or thermostat would fail. Also I like to carry spare hoses and belts when I travel and with the old units I know they will fit. How many times have you bought a v-belt, hose, u-joint etc just to find out it is wrong and all the parts guy can say is that is what the screen said.
Old Mar 13, 2007 | 11:49 PM
Dave Severson's Avatar
Dave Severson
You might also want to check and make sure the installer is putting in a quality chain and gears set. If your truck is a "keeper" it's worth the extra $$$ to put in a roller chain, or possibly even a double roller chain and gears set. I use Cloye's in every engine I have apart. They cost a bit more, but quality usually does....
Old Mar 15, 2007 | 04:57 PM
68bluebeast
can someone give me some links to a couple of good timing chains, thanks
Old Mar 15, 2007 | 08:26 PM
Mil1ion's Avatar
Mil1ion
C3029X
http://www.rockauto.com/catalog/x,ca...,parttype,5756
Old Mar 16, 2007 | 04:26 PM
68bluebeast
if I get a double roller will i need to get a different timing cover or will it not rub, its a 360
Old Mar 16, 2007 | 07:41 PM
Dave Severson
They do make double rollers for the FE engines. Check with any of the engine parts sponsors on the left, quite sure a few of them handle Cloyes....
Old Mar 16, 2007 | 08:18 PM
68bluebeast
also How would I know if I have a fan clutch for the water pump, would this be the right one? it sounds like a good one
http://www.partsamerica.com/ProductD...ype=54&PTSet=A
Old Mar 17, 2007 | 08:18 PM
Mil1ion's Avatar
Mil1ion
There are 2 sizes of water pump flange noses
1/2" & 3/4"
The Truck with fan clutch usually take the larger one.
Just measure the one you have with a vernier caliper first.
Old Mar 18, 2007 | 03:00 AM
ford390gashog's Avatar
ford390gashog
Dennis,
As far as I understand the FE only used the 1/2'' nose. Only the FT used the 3/4 on the 361/391FT thats also the way all my parts book list it.
Old Mar 18, 2007 | 03:16 AM
68bluebeast
So would the water pump that I linked will work
Old Mar 18, 2007 | 02:39 PM
Mil1ion's Avatar
Mil1ion
How do you know if you have a fan clutch?
you will have this.
http://www.partsamerica.com/ProductL...For=Fan+Clutch
The Ford book only shows the length of the shaft not the size of the nose of the shaft.
I'll check my water pump application book if I can find it.
but you need PW-138
Old Mar 18, 2007 | 04:21 PM
68bluebeast
whats wrong with the one I linked? it says it is for a 68 ford with a 360
Old Mar 18, 2007 | 08:20 PM
Mil1ion's Avatar
Mil1ion
Nothing as far as I can see. do the numbers cross over to PW-138 ?
