First Mod
Old Aug 12, 2011 | 03:00 PM
truckrider814's Avatar
truckrider814
First Mod
So i ordered a 3" down pipe for my 97 it got here but i think they sent me two cause it's the exact same pipes just twice two seaparte boxes. anyhow and thursday i have my 6637 coming now to make time to put this stuff on. next is guages and then chip.
Old Aug 12, 2011 | 03:18 PM
fordpride's Avatar
fordpride
If they didn't charge you twice then you could be nice and send it back or keep it and sell it. That's two good mods to start with next you need to lose your cat and get rid of the muffler
Old Aug 12, 2011 | 04:06 PM
truckrider814
oh thats what this dp does makes it 3" all the way down and gets rid of the cat. I have to call Clay an see what i need to do. it's the mbrp dp kit from his site.
Old Aug 12, 2011 | 04:58 PM
fordpride's Avatar
fordpride
The dp is going to stop at the front of the cat. The stock pipe is 3 1/2" pipe
Old Aug 12, 2011 | 08:14 PM
truckrider814
Well that sucks the discription said it would replace the cat
Old Aug 13, 2011 | 09:44 PM
thebig350's Avatar
thebig350
Hi there, Kyle, are you saying you ordered this system?
Riffraff Diesel: MBRP 3" Aluminized Downpipe
It states in the description:
The down pipe back type system mounts to the short stock down pipe in Powerstroke equipped vehicles and eliminates the catalytic converter. The objective is to provide the absolute lowest exhaust gas temperatures, maximum exhaust flow, torque and horsepower possible. The ideal configuration for off road applications.
So it has me a little confused too, if this is what you ordered.
Old Aug 13, 2011 | 10:03 PM
fordpride's Avatar
fordpride
That's the one I have and it goes to about the same spot a the stock DP but doesn't have the flang that bolts to the cat
Old Aug 13, 2011 | 10:09 PM
thebig350's Avatar
thebig350
Yeah, that's what had me confused, from seeing the picture without the flange I thought it looked way to short to go into the junction behind the cat. I guess you are supposed to buy a chunk of straight pipe to join behind the cat somewhere??
Old Aug 14, 2011 | 12:48 AM
truckrider814
Yeah that's the one I got guess I gotta go get a piece of pipe can't have a cat haha
Old Aug 14, 2011 | 01:16 AM
IDMooseMan's Avatar
IDMooseMan
If you received two separate boxes, they might have sent a duplicate dp by mistake. Give 'em a call to verify. Make sure you ask for the cat-delete, or to be "legal", ask for the "test pipe" so you can run an open exhaust when you're racing.
Old Aug 14, 2011 | 07:38 AM
Talyn's Avatar
Talyn
my MBRP eliminates the Cat.
Thats what is in my truck.
Old Aug 17, 2011 | 11:05 AM
truckrider814
So it's just cut the old one out an put in the new an cut the cat off an connect? I'm not much on exhausts my 91 had a peiced Together setup so nothing was normal.
Old Aug 17, 2011 | 12:16 PM
1800joedaddy's Avatar
1800joedaddy
Hang on to both until you have 1 installed, there's been more than a few that were made wrong. Mine worked fine but the only catch with mine was a poor union of the collar and upper dp. There was a lip at the bottom that stuck up about a 1/4" just enough to impede flow imo. I just hammered it down with a ball peen.
ramrod7373
May 4, 2010 04:05 PM
Powerstrokeredneck70
Sep 9, 2008 03:04 PM
wmiller
15
Oct 15, 2007 10:37 AM
Kenworth
18
Sep 28, 2005 05:30 PM
3 of 7
May 15, 2005 09:53 PM
