Actually most of us call that the PCM, and depending on what code it is programmed with will determine whether or not it will work with your truck. They are not plug and play, especially considering you have a manual trans.
Was wanting to get an IDM, to try out the 140v mod.
If you plan to get custom tunes don't waste your time on the 140V Idm Mod. Jody considers what type of IDM you have when doing custom tunes, as I am sure any good tuner does. The IDM mod very, very slightly advances the SOI (Start of Injection) timing. SOI timing is part of custom tuning. I'm still running my stock 110V IDM. If I even put in a 120V IDM I would want new tunes because it would effect the custom SOI timing I now have.
o-yeah, tunes definitely, just cant figure out, why i havnt pulled the trigger on them yet
