PCM issue
Old Jul 27, 2011 | 12:55 PM
fsheare's Avatar
fsheare
PCM issue
I can't see why you must use a pcm with the same # on it. Would not a 2003 pcm placed in a 1999 truck bring up the hp to 250 and have all the improvements from ford in it. Since everything else in/on the engine is the same, aren't the newer pcms just updated for performance improvements????
Old Jul 27, 2011 | 04:12 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
In 1999 Ford started using multiple DPC-families for almost every year. Depending on if it is Federal or California coded you will need a specific PCM code to match it. Example-If you run a Fed coded PCM in your Cali coded truck your glow plugs won't work right when the temps drop. You may be able to start the truck with an unfamiliar PCM code but it won't run correctly. For example I really like knowing how fast I am going and despise seeing the water in fuel light come on when you put the wrong DPC family pcm in and try to use it.
The only pcm you can gain anything from is a well tuned one.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Jul 28, 2011 | 10:40 AM
fsheare's Avatar
fsheare
Still can't get my head around this. All sensors feeding the pcm are the same in all the 7.3 trucks for all years 1999-1/2 to 2003. Virtually every engine/trans. management sensor is identical. So, if all are the same, then different pcms shouldn't matter except for different engine/trans. strategy changes??? Depending on Ford learning as time goes by and changing pcm strategies to compensate for problems encountered in trucks as time goes by. If different pcms do weird things, what is causing the changes???????
wtroger
2004 - 2008 F150
Sep 8, 2018 11:34 PM
noplugs
Apr 8, 2011 09:04 AM
CREECY Strokin It!
Apr 5, 2011 03:28 PM
