sending unit?
Old Aug 12, 2011 | 03:11 PM
lucky_strike's Avatar
lucky_strike
Thanks numberdummy, I only say the gauge because I was told that I couldn't buy the gas guage by it self. I know its not the sending unit I just replaced that and when I grounded the wire the gauge didn't move.
Old Aug 12, 2011 | 03:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All the gauges were sold by themselves, were not sold with the cluster. The cluster was not sold as an assembly either, all individual parts: Lens, cluster bezel, cluster back, gauges and etc etc etc!
Of the 37 NOS available fuel gauges (C7TZ-9280-D ~ 1967/70 ONLY), GREEN SALES CO. in Cincinnati OH has 29 = 800-543-4959.
But...what year is it? You haven't mentioned this important fact. I looked at your profile, it sez 1969 F100. If a 1971/72, this fuel gauge is in-correct.
Old Aug 12, 2011 | 03:36 PM
lucky_strike
Thank a lot for the info. I will be ordering from them next week
Old Aug 12, 2011 | 03:38 PM
lucky_strike
Ohh Im sorry, I have a 69 f100, ranger
Old Aug 13, 2011 | 12:30 AM
DrainBramage's Avatar
DrainBramage
Inside the speedo cables housing is a woven steel core. It is supposed to be lubed every so often, but most peeps are unaware.
Out of curiosity, how does one lube one of these cables? I've no idea how to get something as thick as lithium grease into something like a spedo cable.
Old Aug 13, 2011 | 06:28 AM
Freightrain's Avatar
Freightrain
Put a glob in the palm of your hand and drag the cable through it while squeezing it lightly. Kinda like packing a bearing. You need to force it into the cable.
BTW, white lithium is a very light grease, not like wheel grease.
Old Aug 14, 2011 | 12:28 AM
DrainBramage
What, just pull the core out of the sleeve, grease it up and slide it back in? Is it really that simple?
Old Aug 15, 2011 | 11:32 AM
Freightrain
Yup. Nothing holds it in place. When sliding it back in(likely from the top if you pull the gauge cluster, then you'll notice the ends are "squared". When you slip it back in, you'll have to turn it slightly to engage it back into the gear down at the tranny end. No biggie.
Just note how far the end sticks out when you unscrew it from gauge cluster. It's only like 1/4-1/2". Just make sure it's the same when you put it back in so you don't hurt it when you screw it back together.
Old Aug 16, 2011 | 08:59 PM
lucky_strike
Gas gauge fixed, replaced the wires. Since then my speedo has stoped working so ill be picking up some grease and a new cable if need be.
Thanks again for all the info guys
Old Mar 26, 2012 | 05:41 PM
cesarp35's Avatar
cesarp35
Trailering
What is the correct ford part# for 1969 f250 Aux 25 galllon fuel sending unit?
Old Mar 27, 2012 | 01:27 PM
72RichB's Avatar
72RichB
jsut fixed my gauge by flicking the switch from auxiliray to cab!!!! must have knocked it when I replaced headlight switch... worth a shot
Old Mar 27, 2012 | 02:54 PM
MIKES 68 F100's Avatar
MIKES 68 F100
white lithium grease comes in a spray can too , great for applications like this
fordnurse
May 8, 2011 08:12 PM
jimmmack
Oct 19, 2010 01:33 PM
Aaron-71
Aug 19, 2010 05:41 PM
Redmanbob
Feb 15, 2009 03:19 PM
jrazky
Feb 1, 2006 11:26 PM
