4-sp swap?
Old Mar 26, 2012 | 03:26 PM
moose_13's Avatar
moose_13
4-sp swap?
I have a 1971 ford f-100 lwb with a 390 and a c-6 behind it i recently blew the head gaskets and i found a dentside ford f-350 dually with a 360 and a 4-speed i was wondering what all will bolt up. i know the engine should fit right in but will the transmission fit, will the drive shaft fit and also will all the clutch linkages work in the older model pickup any help would be appreciated. thank you for your time
Old Mar 26, 2012 | 08:25 PM
68cabby's Avatar
68cabby
My truck currently has a 360 and a 4 speed in it. It should work, you may need to find a longer driveshaft, but thats not a definite thing.
Old Mar 27, 2012 | 12:52 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Since the 4 speed was offered in the early trucks it should bolt up fine. Just take as much from the dually as you can, linkage, trans mount, driveshaft, it should all work.
Jim
Old Mar 27, 2012 | 03:32 PM
moose_13's Avatar
moose_13
thanks. what do you think the gears will be like. should it have a granny gear? i haven't looked at the truck over in depth yet but i will probly look at it this weekend.
Old Mar 27, 2012 | 07:14 PM
Nighteyez's Avatar
Nighteyez
Most likely it will be the granny gear 4 speed. Not sure which years had them, but I know they were in the 1970 model year.
Jim
Old Mar 27, 2012 | 08:39 PM
crazed87bronco's Avatar
crazed87bronco
Like others said get as much of the drivetrain from the donor truck as possible everything should be a bolt in deal clutch pedal may need slight alterations z bar clutch linkage crossmember only thing that may give you trouble is the driveshaft
1970RangerXLT
Feb 18, 2013 07:12 PM
83F350351w
21
Nov 18, 2009 05:26 AM
bwebmonster
Aug 27, 2004 11:27 AM
joefords
Nov 16, 2003 06:24 PM
clutchcover
Jul 11, 2003 11:02 AM
