sending unit?
Old Aug 10, 2011 | 10:44 PM
lucky_strike's Avatar
lucky_strike
sending unit?
Well I checked out my sending unit and the float was filled with gas so I replaced it with the one I bought from lmc. In stalled it but nothing has changed, I'm going mad trying to find out that the problem is. I just had to unexpectedly replace the raditior and ingition coil so the well is almost dry for the next two weeks. Anyone have any ideas on what's causing the sending unit to do this?
Old Aug 11, 2011 | 12:33 PM
Freightrain's Avatar
Freightrain
Did you test to see if the gauge works? Take the hot wire at the sending unit and touch it to ground. Should make the gauge move.
Or remove the sending unit and move the arm to see if gauge moves. I'm assuming the issue is the gauge doesn't reading?
Old Aug 11, 2011 | 12:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TZ-9275-G (replaced D0TZ-9275-A & C1TZ-9275-K) .. In-Cab Fuel Tank Sending Unit / Obsolete.
Applications: 1961/66 F100/700 / 1967/77 F100/750 // 1963/69 N/NT500/750 / 1964/69 F750/800 w/FT engines.
COAZ-9202-B .. Fuel Sending Unit Float / Available from Ford.
Applications: ALL 1957/79 Passenger Cars/Trucks, 1961/79 Econolines & 1966/79 Bronco.
Old Aug 11, 2011 | 04:52 PM
lucky_strike
I did the test where you ground the wire and nothing, so I'm guessing its the gauge..I there a place that still sells them? Couldn't find them in lmc or npd
Old Aug 12, 2011 | 04:30 AM
NumberDummy
1961/77 In-Cab Fuel Tank Sending Unit
Applications: 1961/66 F100/700 / 1963/69 N/NT500/750 / 1964/69 F750/800 w/FT engines / 1967/77 F100/750.
Last MSRP: $118.33 / Dealer net cost: $71.00.
SMACKOVER MOTORS in Smackover AR has ONE = 870-725-3961.
NELSON FORD in Martinsville VA has ONE = 276-638-2331.
SWAFFORD'S FORD in Richmond MO has ONE = 816-776-2288.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
COLLECTORS AUTO SUPPLY in Oroville WA has ONE = 800-414-4462.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 607-722-5371.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
VINTAGE FORD PARTS in Beaver Dam WI has TEN = 877-846-8243.
Old Aug 12, 2011 | 07:31 AM
lucky_strike
Is it just the gas gauge or do I have to get all the guages?
Thanks for the. Info numberdummy
Old Aug 12, 2011 | 08:59 AM
Freightrain
Does your other gauges work? or do you have idiot lights?
There is a voltage regulator(small resistor) on the back of the cluster that drops the voltage for everything to read correctly. If that fails, nothing will work(if you have oil pressure/water temp gauges).
Old Aug 12, 2011 | 09:02 AM
lucky_strike
I have a guage for the temp, that seems to read fine
The speed omter will shake until I reach 40mph
the oil and the one that reads alt are both lights
Old Aug 12, 2011 | 09:34 AM
Freightrain
If water temp reads fine, then likely it's just the fuel gauge that is faulty.
Speedo sounds like a bad cable. It will cause it to jump around at low speed. If the cable gets a flaw in it(braiding comes apart), or gets dry(no lube), it will stick and cause jumping.
Old Aug 12, 2011 | 09:46 AM
lucky_strike
I didnt know that about the cable thanks. As for the gauge do you know of a place that has them?
Old Aug 12, 2011 | 10:41 AM
Freightrain
Likely no one will have "new" gauges. Might look at the back of the panel and see if there is a break in the wiring. There is a clear plastic sheet that holds copper strips, also check the plug also as it's kinda a crude set up and could just be a bad connection.
You might just have to check around and find another cluster? I scrapped out my '67 couple years ago, but sold the cluster already. I know it had idiot lights, so it might have worked for you. Check the classifieds.
You can pull the speedo cable out of the housing and check it. Nothing holds it in, it's free floating. Slip it out one end, if it's just dry, you can lube it. Needs to be very light, like white lithium(or graphite is what it's suppose to have). Slip it back in and see. If the cable is fraid, then it needs replaced.
Old Aug 12, 2011 | 10:47 AM
lucky_strike
Aright well thanks a lot, ill be on the look out for a new cluster, as for the cable is it hard to replace if I need to?
Old Aug 12, 2011 | 01:48 PM
NumberDummy
There is a voltage regulator (small resistor-ICVR) on the back of the cluster that drops the voltage for everything to read correctly. If that fails, nothing will work (if you have oil pressure/water temp gauges).
All these trucks have a fuel and temp gauge as standard equipment. Oil and amp gauges were an option over the idiot (warning) lamps that came standard equipment.
The ICVR = Instrument Cluster Voltage Regulator, when it fails, does not affect the amp gauge, and AFAIK, not the oil pressure gauge.
When the ICVR begins to fail, the needles of the temp and fuel gauge do "the hula" .. swing back/forth on their own.
C6DZ-10804-A .. ICVR: 1967/69 F100/350. 1970 F100/350 is one year only (C9AZ-10804-A). 1971/86 is the same (D1AZ-10804-A). Instrument cluster: 1967/69 have wiring, 1970/72's have a printed circuit board.
Jumping speedo can be caused by several factors: Worn gears in the speedo's odometer, a stripped nylon speedo DRIVEN gear (end of the cable) and/or a stripped DRIVE gear (on the output shaft).
Inside the speedo cables housing is a woven steel core. It is supposed to be lubed every so often, but most peeps are unaware.
When the lube dries out, the woven steel core binds up inside the housing, sooner or later...it snaps. A "universal" woven steel core can be bought in any autoparts store.
You cut it to length, coat it with graphite (or a fine film of white lithium grease), install in the housing. The DRIVEN gears are still available from Ford. The nylon DRIVE gears are replacedable only if the truck has a M/T.
If an A/T (C4/C6), the steel DRIVE gear is made as part of the output shaft.
Old Aug 12, 2011 | 02:43 PM
lucky_strike
So numberdummy do you know if there are any shops that have the cluster gauges?
Old Aug 12, 2011 | 03:05 PM
NumberDummy
Why replace them if you aren't sure you need to? Why replace them all if only the fuel gauge is the problem?
It could be the dash gauge, and/or the sending unit, and/or the ICVR, and/or a grounded or cut wire.
Throwing money at the issue won't do anything...except empty your wallet.
C7TZ-9280-D .. Instrument Cluster Fuel Gauge-1967/70 F100/350 / 1969/70 Econoline / Obsolete
37 available NOS from FoMoCo Dealers/obsolete parts vendors.
