Sponsored by: Auxito
ABS Light
Old Aug 9, 2011 | 07:12 PM
Jrakar's Avatar
Jrakar
ABS Light
1998 F150 - with 123k miles and not a 4x4. My ABS light came on this afternoon going down the highway and stayed on till I got to work. On the way home it was off for about 5 miles and then came back on. Any advice on what this could be would be great.
Old Aug 9, 2011 | 08:59 PM
Dave G.'s Avatar
Dave G.
Check the ABS sensors on the back side of each brake rotor. Also check the sensor rings for damage or rust/mud build up.(they look like gears, with teeth around the perimeter). Sometimes the sensor (s) is good, and the 2 wire harness has been either damaged or unplugged.
Dave
Old Aug 9, 2011 | 09:25 PM
steve(ill)'s Avatar
steve(ill)
since the lilght was off at startup, the computer is seeing a good circuit. If the light comes on as soon as you start moving, then the speed pickup is not sending a signal. if the light comes on several miles later, normally the oil is dirty or the speed ppickup end is dirty and not getting a constant good signal. Our EXP did this. I took the pickup out of the rear pumpkin, cleand the end off, reinstalled and it worked for 1 year. Eventually i needed to get a new pickup. IT worked, but weak signal.
RLTotten
1997 - 2003 F150
Nov 15, 2012 03:07 AM
peter p
1997 - 2003 F150
Jan 25, 2010 10:26 AM
dogman
Feb 28, 2006 06:01 PM
lpallen
1997 - 2003 F150
Jun 24, 2004 08:49 AM
