Sponsored by: Auxito
Help Help Engine Issue
Old Aug 9, 2011 | 06:06 PM
97F150RED's Avatar
97F150RED
Ok so here it is. My truck started shaking like it wsa loosing power a week ago but no codes. A day went by and then it thur a code for #5 cylinder misfiring. The coil packs were OEM original with 186000 miles. I replaced the coil packs and cleared the codes. Truck ran good for a couple miles but once I hit 60MPH it started doing it again but hasnt thrown a code yet. It is almost like the truck wants to shut iff but still keeps goen forward till I let off the throttle. Please any thoughts on what this is. The plugs only have 20,000 on them so I didnt change them primarily cause they suck to get to.
Old Aug 9, 2011 | 09:46 PM
Bluegrass 7's Avatar
Bluegrass 7
You still have another faulty coil.
The fault is shorted turns. It won't set a code so becomes difficult to find which one because it's not a hard fault.
Good luck.
Old Aug 9, 2011 | 11:22 PM
97F150RED's Avatar
97F150RED
Bluegrass should I be changing my wires and plugs? Do you think that may be the cause. I replaced both of the coil packs but not the wires. I am pretty sure tthe wires were replaced with the plugs but I am not possitive that I did them in the past
Old Aug 10, 2011 | 12:20 AM
Bluegrass 7
The tipoff is the 45 to 60 mph drivability issue.
The EGR operates and leans the fuel/air ratio out.
If one coil cannot fire the lean mix you feel it as a missfire.
It usually will clear once the EGR closes until you the next time the driving condition is entered.
If the coil gets bad enough you may feel a miss at times at low speed from a stop for some short time.
Good luck.
sam hain
1997 - 2003 F150
Mar 21, 2017 09:30 AM
WillaminaOR
1997 - 2003 F150
Sep 20, 2016 02:10 PM
plug-n-jug
1997 - 2003 F150
Oct 19, 2013 06:51 AM
JoshsF250
Sep 2, 2011 08:16 PM
haldavis
3.8 & 4.2L V6
17
Dec 11, 2008 06:33 PM
