Sponsored by: Real Truck
05 transfer case question
Old Aug 8, 2011 | 01:03 PM
lakewood's Avatar
lakewood
I went and bought mercon v to change my tranfer case fluid and it said on the back of the bottle: "Do not use in transfer cases." And the parts guy at ford said thats all they use at the dealership. so i returned it.... Anyone else have this experience with mercon v? or what else could i use?
Old Aug 9, 2011 | 07:28 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That's strange. Was it Ford/Motorcraft fluid that said this?
Old Aug 9, 2011 | 10:44 AM
bpounds's Avatar
bpounds
Was it Motorcraft brand? I think I remember seeing that too. As you know, Mercon ATF has been replaced by Mercon V and is backwards compatible, EXCEPT they say not to use it in T-cases. And, there is now a dedicated Motorcraft T-case fluid.
I solved the problem by just going with Mobil-1 synthetic ATF fluid. Has been fine for a couple of years now.
Here is the Motorcraft transmission fluids page, and it shows the T-case fluid, as well as the note you mentioned on the Mercon V.
http://www.fordparts.com/Products/Ch...ionFluids.aspx
Old Aug 9, 2011 | 11:16 AM
lakewood's Avatar
lakewood
Motorcraft® Transmission Fluids
Yes it was motorcraft brand mercon v, bought it strait from the dealer, when i asked the parts guy he said thats all they use in the trucks they service....... Im not sure if he didnt know what he was talking about, or if they really use the wrong oil in their transfer cases... Oh mercon sp got replaced by mercon lv now too
Thanks for the link
Old Aug 9, 2011 | 11:22 AM
bpounds's Avatar
bpounds
I learned the hard way that you cannot trust the dealerships to use the correct fluids.
Old Aug 9, 2011 | 11:26 AM
lakewood's Avatar
lakewood
Exactly why i work on my own truck. Whats is the oil for the transfer case, that variable chain oil?
Old Aug 9, 2011 | 11:45 AM
bpounds's Avatar
bpounds
If you want to use Motorcraft, it is this stuff;
I used this stuff;
Mobil 1 Synthetic Automatic Transmission Fluid (ATF)
Old Aug 9, 2011 | 12:00 PM
3000 FPS's Avatar
3000 FPS
I use amsoil synthetic transmission fluid in the transfer cases of both my trucks. It has been about 3 years and never a problem. I believe the synthetic fluid will make the transfer cases run at lower temperatures due to less friction.
Syncrowave
30
Sep 28, 2017 08:33 PM
hamster
Apr 20, 2016 06:20 AM
96mark8
Sep 28, 2013 01:17 PM
bigred66
Aug 21, 2010 03:38 AM
rvm264
Dec 23, 2002 01:53 PM
