F250 AC Compressor not Cycling
I have a 2002 F250 on which the AC compressor clutch is not cycling: I have checked and added coolant so low pressure is correct (don't have high pressure gauge). I checked the clutch air gap and it is at 0.030 " as specified in another post. I replaced the low pressure AC cycling switch (on the evaporator/dryer). With the AC on, I disconnected the AC cutoff switch and the clutch disengages. This circuit has the correct (>10V) going to it. I am thinking it could have something to do with the AC relay. Any ideas, suggestions?
Note: When you switch the ATC to a setting other than AC or Max AC, the clutch disengages fine.
I noticed this problem because the AC shuts off when it is really hot, after I have been driving for a long while, about 1 hour or more. If you shut off AC, wait a few minutes, then turn on it works fine.
Last edited by VA250SD; 08-08-2011 at 03:16 PM. Reason: Add More Info, Post in AC Forum
jwhopson
08-20-2015 05:57 PM
VA250SD
05-12-2012 11:58 AM
mike3000sx
1997-2006 Expedition & Navigator
05-21-2004 09:03 PM
01, 1999, ac, air, compressor, conditioner, cycling, duty, edge, f250, ford, specifications, super, turn, wheel
