intermittent problem
Old Aug 8, 2011 | 11:43 AM
dagren99's Avatar
dagren99
2001 7.3L symptoms:
stalls while idling, stumbles occasionally while driving but otherwise seems fine.
We thought CPS but after swapping that with no effect we're thinking IPR but the symptoms don't seem right since it drives fine otherwise
Suggestions or are we headed in the right direction?
Old Aug 8, 2011 | 11:50 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Your tin nut on the IPR could be lose, also check the ICP plug for evidence of oil if there is oil in the plug it could be sending a bad signal.
Old Aug 8, 2011 | 11:51 AM
riverrat41's Avatar
riverrat41
Have you done the .50cent mod?Do you get a CEL?
https://www.ford-trucks.com/forums/8...ck-shakes.html
Old Aug 8, 2011 | 11:58 AM
dagren99's Avatar
dagren99
No CEL which is why we keep thinking CPS but this truck does have its original IPR. We've looked things over but it sounds like another round is in order.
Old Aug 8, 2011 | 12:08 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
You could give this a try.
http://www.dfuser.com/Install%20Guid...0Regulator.pdf
danielwilhem
Jun 22, 2018 09:00 AM
kx125str99
24
Dec 19, 2017 06:35 PM
zack7.3
Sep 14, 2008 08:05 AM
Clint Knotts
Jul 9, 2006 12:03 AM
snoracer00
Mar 25, 2006 10:33 PM
