power steering problem
Old Aug 6, 2011 | 11:29 PM
tygerrrr's Avatar
tygerrrr
Question power steering problem
hey guys would any buddy have any idea why my power steering pump keeps going out i first replaced my power steering pump worked great for the first day then started to go out again so i changed my steering gear box didn't fix anything so i got another power steering pump worked good for the first 2 days then went out again its wired cause when i turn to the right or the left its only hard for a little bit then goes back to kind of working again and it gets worse the longer i drive it. does anyone have any idea why it would do this.
Old Aug 7, 2011 | 11:01 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
what are you using for replacement pumps? new,used,brand,etc?
its gotten so bad,we're all turning our used vehicles into China made due to the parts stores only offering the lowest quality parts.
Old Aug 7, 2011 | 12:15 PM
tygerrrr's Avatar
tygerrrr
There refurbished pumps from pep boys I can't remember the brand
Old Aug 7, 2011 | 01:25 PM
Marianna2003's Avatar
Marianna2003
Does the fluid have shavings in it when you take it off? I've seen systems that were intentionally contaminated grinder sump trash run for 500-600 miles and still function normally. What does PEP BOYS have to say?
Old Aug 7, 2011 | 02:49 PM
tygerrrr's Avatar
tygerrrr
No the fluid looks good I flushed the hole system out before I put the first pump in and pep boys didn't say anything they just give me new pumps
Old Aug 7, 2011 | 08:58 PM
snaponprofile's Avatar
snaponprofile
I put a cardone in mine and it is trouble free. Cardone makes good parts(I know the vice president of the company).
Old Aug 7, 2011 | 09:19 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hmm, hard then soft again sounds like it could be air or a bent stabilizer. Sorry about your bad luck.
Old Aug 8, 2011 | 05:50 PM
bghnkinf250's Avatar
bghnkinf250
I agree with trying the Cardone pumps - I had an issue and was contacted by a rep immediately. Good customer service! Or upgrade to the Saginaw!
Old Aug 8, 2011 | 08:39 PM
IDIDieselJohn's Avatar
IDIDieselJohn
X2 on Saginaw pump!
Old Aug 8, 2011 | 09:25 PM
ford390gashog's Avatar
ford390gashog
Okay something is wrong!!!
Did you flush the entire PS system and install a PS filter??
You sure its not your box feeding pieces into the pump (would not happen if you had a filter)
You made sure NOT to use a hammer to install the PS pulley and only used the supplied kit(Or nut , bolt and fender washer)
Old Aug 9, 2011 | 12:36 AM
tygerrrr's Avatar
tygerrrr
ya i flushed the hole system, didn't install filter, installed new steering gear box, and no didn't use a hammer to install pulley.
would metal shaving make my power steering go in and out and get worse when it gets hot?? cause it doesn't leak.
Old Aug 9, 2011 | 03:37 PM
Marianna2003
It really sounds like a bad bushing/tierod end. If it gets hard then eases up as you continue through your turn.
Also, I have heard of the inner liner of hoses to delaminate and cause problems. You might try blowing out (w/compressed air) your lines in both directions. If it did delaminate you might find it. A visual inspection of each end where the fitting transitions to the line is where I would expect to find a problem. Whatever it is, there are millions of system working, It's going to be somrthing really unusual. Good luck and let us know what you find.
BBpwer
Jan 21, 2017 12:05 PM
raiderman
2004 - 2008 F150
Oct 10, 2004 08:53 AM
Adriand
Mar 15, 2004 06:14 AM
jailbird 88
Oct 18, 2002 12:17 PM
