Clutch Issues
Old Aug 6, 2011 | 12:55 PM
blue66tang95f150's Avatar
blue66tang95f150
Clutch Issues
Hey guys. I have been very happy with my truck for the past 40k miles. Before that I was getting pretty sick of it. I was tired of fixing all the little things that kept going wrong. Anyway, I have done nothing in 40k, but I have always had a clutch problem. The clutch has to be pushed all the way down to the stop for it to disengage. This is not a huge deal for me because i am 6'5", however nobody wants to just hop in and move my truck cause nobody can get it into gear and shift the dang thing. I even have a hard time getting it into gear sometimes. The clutch just does not disengage enough. What the heck is wrong with it? there is ZERO play between the pedal master-cylinder. I have even tried new bushings, but that did nothing. Again there is zero play. So it has to be in the master, slave or clutch.
Any help?
Old Aug 6, 2011 | 01:56 PM
rideracelivemx7's Avatar
rideracelivemx7
its just time for a new clutch, home many miles are on her?
Old Aug 6, 2011 | 02:23 PM
blue66tang95f150
245k,
I bought the truck at 170k, and I have no idea if/when the clutch was done before.
Old Aug 6, 2011 | 06:40 PM
BuckHammer's Avatar
BuckHammer
You way want to swap to a solid mass flywheel while you're in there. That's a very popular mod around here.
Old Aug 6, 2011 | 08:39 PM
Talyn's Avatar
Talyn
Clutch fork could be damaged, the clutch fork pivot bushing could be worn.
and the throw out could be worn as well
All these can contribute to your issue
Old Aug 6, 2011 | 09:57 PM
540milotalon's Avatar
540milotalon
All of the above, could also be pedal play, worn bushing/rod.
Old Aug 6, 2011 | 11:11 PM
BuckHammer's Avatar
BuckHammer
He said play in the pedals and bushings is not an issue.
Old Aug 6, 2011 | 11:22 PM
540milotalon
Sorry, I read bushings, did not pick up on "zero play" I would think if there is still a dual mass, that's it. The last one we had go you had to pump 27 times to get in 1st gear and it would scrape when shifting if you did not watch RPM's.
Old Aug 7, 2011 | 11:22 AM
blue66tang95f150
Well I guess this winter I will dig into it and replace everything clutch related. I need to replace the ball joints too. I will probably put it in the shop for a couple of weeks and just get everything fixed up. I have been watching for a dana 60 cause I really don't want to put money into the ttb front end, but i guess It has lasted 245k with out any major problems, why couldnt it go another 100k+.
....hmm bigger injectors sound good too
Old Aug 7, 2011 | 11:41 AM
rideracelivemx7
little FYI, the pivot ball only comes in kits of 2 at the tune of 45$ each. so call around, alot of ford dealers i found dont stock them. i found one that had 1 left, ever one else would only sell 2 of them in 1 order. but i think your on the right track, order a nice kit from valair if your thinking injectors and do every thing over. single mass fly wheels can make some noise in neutral some times other than that i couldnt be happier with mine.
Old Aug 7, 2011 | 11:55 PM
blue66tang95f150
Oops sorry I switched subjects on ya. I was talking about the front ball joints on the front end.
Old Aug 8, 2011 | 07:59 AM
Talyn's Avatar
Talyn
New one to me.
I bought 1 without any issues.
Vaunripped
Aug 15, 2016 10:04 PM
Stymied
21
Jun 13, 2016 09:23 PM
d3ryl
Apr 26, 2009 08:08 PM
BobI
Apr 19, 2005 03:18 PM
bcsbadboys
18
Dec 3, 2002 03:11 PM
