Need help please!
Old Aug 5, 2011 | 03:55 PM
snorindad's Avatar
snorindad
Need help please!
I started tearing down the engine today and for some reason can't get turbo off. It is loose but the exhaust will not come loose from it. the clamps are loose but just can't get them off. Is there some trick to it? Thanks
Old Aug 5, 2011 | 04:47 PM
snorindad's Avatar
snorindad
never mind got it.
Old Aug 5, 2011 | 04:52 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by snorindad
never mind got it.
Sorry---didn't see it until now. If you're referring to the sectioned clamp on the back of the turbo I usually pop them off starting at the split and work my way around. They can be difficult to remove as well as intall.
Old Aug 5, 2011 | 06:02 PM
cheezit's Avatar
cheezit
spary them down with wd-4- 90% of the time they will pop right off.
Old Aug 5, 2011 | 08:42 PM
BLADE35's Avatar
BLADE35
and smear them with antiseize when you put them back on
Old Aug 5, 2011 | 09:07 PM
snorindad's Avatar
snorindad
Thanks for the info. I finally did get them off. I do appreciate the help.
Old Aug 5, 2011 | 09:13 PM
BLADE35's Avatar
BLADE35
what are your intentions with the truck is it broke or just PM
Old Aug 5, 2011 | 09:31 PM
snorindad's Avatar
snorindad
arp studs, coolant filter, BPD erg cooler, new oil cooler, new radiator, new heater core, I already have the updated turbo oil feed and drain tube, all new hoses, belt, 6.4 banjo bolts, blue spring, Cat ELC, new oil and fuel filters. My delta was 21* and I had puking out my degas bottle with my 15k toy hauler so I decided to do the works. I am having the works done to my heads as well.
pgg00
Jun 5, 2016 12:52 AM
Hotwheelbill
Jan 15, 2014 05:56 AM
THEDON117
18
Sep 30, 2011 09:30 PM
randomhero1172
13
Jun 12, 2008 09:56 PM
tm0231009
33
May 22, 2008 07:12 AM
