Turbo Removal Trouble!!!
Old May 19, 2008 | 09:36 PM
tm0231009's Avatar
tm0231009
Needing some help guys. Trying to put a WW in a turbo and cannot get the turbo removed. The only thing holding me back is the EBPV rod. I am almost certain that is what it is. It is the rod that is pretty much directly underneath the turbo.?. I think there is a certain way you are supposed to push it but I can't seem to get it Any help would be greatly appreciated. Thanks in advance.
Old May 19, 2008 | 09:45 PM
big poppa's Avatar
big poppa
I wish i could help you but i did my WW with the turbo on. Bumping you back up. Good luck.
Old May 19, 2008 | 09:48 PM
tm0231009's Avatar
tm0231009
Well thanks any way - You can help me with something then - how do you get your signature on and how did you go about putting it in with the turbo on because I still have another one to put on after this and this is a PITA. Thanks
Old May 19, 2008 | 09:49 PM
megawatt00's Avatar
megawatt00
Welcome to FTE!!!
Maybe this thread will help:
99-03 Turbo Removal & Wicked Wheel Installation .: Articles
Old May 19, 2008 | 09:52 PM
greedy737's Avatar
greedy737
Hang in there! Others with more knowledge will help you out soon!! And Welcome to FTE...
Old May 19, 2008 | 09:55 PM
tm0231009's Avatar
tm0231009
Thanks You Guys For All The Help So Soon!! I'm Already Loving Fte!!!
Old May 19, 2008 | 09:59 PM
clux's Avatar
clux
grab the clip with a pair of needlenose pliers, and push/pull towards the driver's side, the clip should come off after it comes loose from the rod.
On edit: here's the writeup on turbo removal:
Old May 19, 2008 | 10:03 PM
greedy737's Avatar
greedy737
Thats why I became a Supporter! FTE has helped me out alot of times! You will soon be helping others out too!!
Old May 19, 2008 | 10:04 PM
big poppa's Avatar
big poppa
I think you got to have enough post to post you sig. As for the WW with turbo on, go to guzzles for ww install and removal. Big time slow .
Old May 19, 2008 | 10:18 PM
zack7.3's Avatar
zack7.3
Welcome to guzzle's Ford PSD Web Page Here is a link to guzzles.
Old May 19, 2008 | 10:23 PM
tm0231009's Avatar
tm0231009
Once again thanks guys for all the help. This site is great.
Old May 19, 2008 | 11:06 PM
aklim's Avatar
aklim
How are you making out with Mr Marmon in the rear?
Old May 19, 2008 | 11:10 PM
tm0231009's Avatar
tm0231009
Who's Mr. Marmon?
Old May 19, 2008 | 11:11 PM
aklim's Avatar
aklim
Who's Mr. Marmon?
The )#@!%)@_ clamp that holds the turbo to the up-pipe. It also holds the turbo to the spider Y but that is in front. Took me 3 hrs to get the clamp out and the turbo back in
Old May 19, 2008 | 11:13 PM
bdrummonds's Avatar
bdrummonds
Who's Mr. Marmon?
The stupid Bast**d who designed that stupid clamp that holds the turbo to the uppipes. Well O.K. hes only stupid when you dont use enough PB blaster.
