E4OD Problem
Old Aug 4, 2011 | 04:45 PM
COUNTRYBOYMMA's Avatar
COUNTRYBOYMMA
E4OD Problem
I bought a 96 F250 7.3 with the E4OD. The previous owner did a diy rebuild after the center shaft broke. If you put the truck into drive, it feels like it starts off in 3rd. If you put it in 1st or 2nd, it starts in 2nd. It will not shift gears while driving. The overdrive light doesn't flash and when I pulled the codes it only pulled something for exhaust back pressure. I figured I would do a pressure check on the trans. Can anyone tell me how to do this? I am worried that the case got scored.
Per Mark, I checked the wiring on the solenoid harness all the way to the pcm. The continuity checks on the harness with no breaks. I also ran a jumper to the solenoid block and all the solenoids audibly opened. Is there a way to get the pcm tested before I spend money on another one?
Old Aug 4, 2011 | 07:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is the +12V to the red wires at the solenoids? It is acting like the solenoids are not powered.
Old Aug 4, 2011 | 08:03 PM
COUNTRYBOYMMA
I'll get everything hooked back up tomorrow. I'll check the voltages again to be sure.
Old Aug 9, 2011 | 07:33 PM
COUNTRYBOYMMA
Ok, This is where I have gotten so far. I checked the power sires to the solenoid harness an I have 12 volts to both of the power wires. I took the truck to a local garage and had them pull the codes. I am still getting the same codes for KAM error and exhaust back pressure. The mech. used a SnapOn Solus, and it said that it wasn't detecting P or N for the KOEO/KOER tests. I replaced the MLPS on a hunch, but it didn't change anything.
I am getting thoroughly confused. Does anybody have any suggestions on where to go next? Am I coming down to a bad PCM? Thanks for the help.
Old Aug 9, 2011 | 08:48 PM
stuart1's Avatar
stuart1
Check wiring to the switch, both ends.
Old Aug 9, 2011 | 08:57 PM
COUNTRYBOYMMA
Do you mean a "wiggle" test?
Old Aug 10, 2011 | 04:20 PM
stuart1's Avatar
stuart1
No.
Remove, disconnect, separate.
Look for corrossion, water, rust and or green fuzzies.
Do the same with battery cables. Both ends.
Todays vehicles are very dependant on clean electricity.
A malfunction at the junction has them throw a hissy fit.
justespresso66
Jul 19, 2015 03:39 PM
knotEdog
Jul 21, 2013 08:50 PM
Forddiesel17
Jan 4, 2012 08:52 AM
COUNTRYBOYMMA
Jul 31, 2011 07:13 AM
JCATC
Apr 8, 2004 07:15 AM
