IS ANYBODY USING CYCLONE/TORNADO GAS SAVER ON 7.3L
I was driving on the interstate yesterday when my cold side turdo tube blew out of its boot. To my surprise I found a CYCLONE gas saver installed. Should I remove it? My 2001 F350 7.3L DSL has operated fine for 100,000+ miles.
Thanks in advance FTE guys!!!!
TORNADO Air Management Systems :: More Power! More Mileage!
This is what was installed on my truck, by previous owner.
[IMG]file:///C:/My%20Documents/CYCLONE%20INTAKE.jpg[/IMG]
Gene had a turbo air guide and swore by it.
Turbo Air Guide - Ford Powerstroke Diesel Pickup Truck - More Air Flow, More Power, Increased Fuel Mileage, Greater Performance --www.blackclouddiesel.com
I might have argued with him about a time or two...............
I would think that if that honeycomb material comes apart for any reason, your turbine blades have BIG problems!
I can't imagine that there is enough reduction to flow turbulence to allow a performance increase enough to overcome the loss produced by the cross-sectional resistance to flow.
Sorry. Got no graphs, charts, bells, whistles, or anything else to prove my thoughts.
Pop
Pop
I would agree with others here that it's a waste of money, but a fews years back I must have had money to waste. For some reason I bought an Air Cell intake spacer for my Kenworth, as seen here:
Fuel Saving Aircell Intake Spacers - IOWA80.COM
It had a money back guarantee, figured I'd try it and could return it when I saw no improvement. I honestly think it helped my truck pull a little harder, and I saw my mileage go up by .2 mpg. Yea it's not alot, but when you put a lot of miles under the tires it can start making a difference. I don't know how or why it made a difference or I felt a difference, but I left it in there. I did like that it didn't really "block" the intake, like that Cyclone does.
Then a year later I sold the truck and bought a new one with a bigger motor and now am getting better mpg than before with a lot easier pulling!!
It did make a difference. You expected better fuel economy so you drove a little better to help it, whether you knew you were doing it or not. If you ran a scientific test like the link above you would have found that at best it didn't hurt you a lot. It certainly wasn't responsible for 0.2 MPG gains. Bad science doesn't work.
When I fuel up every 2 days putting in close to 200 gallons each time and I consistantly have slightly better mileage than before, something made a difference. I drove it exactly the same as I always did, with the pedal to the floor cuz the trailer I was pulling would dog the crap out of my truck.
Scientific tests are great, but they are in a controlled environment. What about real world experience? If what I see in my "real world test" doesn't line up with what someone found in a "scientific test" in a lab, my results are automatically ruled out? Why?
I wouldn't buy it again, and I'm not saying for the OP to keep it in there. I'm just sharing my experiences.
