I need the OEM 7-way plug for a 2004 F-150. The 4-way slot is there, but the 7-way with a cover is not, just the plug behind it on the end of the wiring harness.
I think I have found what I need here: The Hitch Corner sells trailer plugs & wiring products It's about a 3rd of the way down, under 7-way plugs, Part # DT_20015. I've requested a picture of the back so I can confirm it.
Any other ideas outside of the dealership where I can look? (Fordparts.com lists nothing related to towing at all.) Trying to avoid paying dealership prices. I've found a whole new 4-way and 7-way OEM set up, but it is for a towing pkg that was install aftermarket - mine is factory installed and well, I don't feel like sacrificing my taillight wiring to make this one work.
Ideas? I need to be hauling a trailer in a week and a half, so if I need to order something and not pay more than the part for shipping I need to do it soon. I really didn't think it would be this freaking tough to find it.
You can get either a #40955 or #40975 Hopkins kit. They both are direct plug-in kits. The 40955 has a short harness and the 40975 plugs directly into the back. You can look them up @ Hopkins Manufacturing's website and Oreilly's sells this brand as well as other parts stores.
I have a 2006 F-150 xlt, I have a 4 way flat tow harness and I've been looking for a 7-way tow harness that I could just unplug the 4 way flat harness and plug the 7-way but every thing I find doesn't look right.
The main plug to the truck is a rectangle, the harness should have three branches of wires, the main branch going to the bumper, I'm not sure where the others go. the ones that I found on Hopkins either are single branch or the main plug look different, and the 7-way end also looks different. Do I have to get adapters?
I would like to get something where I don't have to hard wire. I need the brakes and the reverse lights to work.
all help is much appriciated.
