Hello all,
Right now I have the flat four factory plug on my truck. I'd like to upgrade to the Round 7 plug/4 plug combination. Does anyone know where I can get this plug - a wrecked truck or something. I've been checking ebay, but there are none for sale right now. Thanks.
Assuming you are talking about your 1999 F-350 I would suggest the Draw-tite 18243. You should be able to find it for around $30-35. This is a harness that simply plugs in to the existing wiring on your truck, and it even comes with the relays to activate the trailer brake circuit. The only hard part is finding a bracket to fit it to your truck. The ones they sell at most stores do not match the bolt pattern on the plug, so I ended up making one myself. Also, this is only a 7 way plug, but I just went to Walmart and bought a $20 7way to 6way/4way adapter.
Otherwise you can go with the Ford parts, but if I remember right they wanted something like $120 fr the harness and $20 for the bracket.
Thanks guys,
Yea, I am talking about my 99 F-250 V10 reg cab. Im hoping that the wiring is already there. I was trying to located a factory plug that bolts right up.
The draw-tite one that I talked about plugs right into a small connector at the back of your truck by the spare tire. Like I said though, you will have to find a way to mount it.
