6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Error codes
Old Jul 27, 2011 | 04:02 PM
silverandscout's Avatar
silverandscout
Error codes
<TABLE style="BORDER-TOP-WIDTH: 0px" class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR title="Post 10628516" vAlign=top><TD class=alt1>error codes
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1>I'm stranded without a truck because the check engine light came on in my 08 F350 SD diesle 6.4L. 76K mi. The error code indicates something in the exhaust/ emissions. The Ford dealer can't find the exact problem so we are waiting for a Ford engineer to come and look. (could be 2 weeks I'm told) Anybody got any advise other than trade it in on a Dodge or GM? </TD></TR></TBODY></TABLE><!-- / close content container --><!-- open content container -->
Old Jul 27, 2011 | 04:14 PM
senix's Avatar
senix
what was the code..try EGT13 sensor
EGR has been known to do the same thing
Old Jul 27, 2011 | 05:00 PM
silverandscout
Error Codes
Thanks for the reply Senix! They did replace the EGR but that didn't seem to do the trick.
Old Jul 27, 2011 | 05:14 PM
cheezit's Avatar
cheezit
whats the code?
Old Jul 28, 2011 | 11:20 AM
silverandscout
Error Codes
the error code is P2452 any help is greatly appreciated.
Old Jul 28, 2011 | 11:43 AM
wp6529's Avatar
wp6529
If the dealer replaced the EGR it sounds like they are not following the correct diagnostic procedures.
P2452 - Diesel Particulate Filter Pressure Sensor A Circuit
Description: The powertrain control module (PCM) monitors the rationality of the diesel particulate filter pressure sensor during idle and part load operating conditions. The test fails when the diesel particulate filter pressure sensor signal value at idle is less than 0.15 kPa (0.022 psi). The test also fails when the diesel particulate filter pressure sensor signal value at part load is less than a minimum value or greater than a maximum value. These minimum and maximum values are based on the volume of exhaust.
Possible Causes: Diesel particulate filter pressure sensor connecting hose is loose, cracked, or missing
Diesel particulate filter pressure sensor connecting hose port is cracked or broken
Excessive amount of soot or ash in the diesel particulate filter
Damaged diesel particulate filter pressure sensor
Diagnostic Aids: Carry out a thorough inspection of the diesel particulate filter pressure sensor and connecting hose. If DTC P2463 is present along with DTC P2452, diagnose DTC P2463 first.
Old Jul 28, 2011 | 11:46 AM
senix's Avatar
senix
Did they look at the EGT13 sensor?
Old Jul 28, 2011 | 12:05 PM
Tom's Avatar
Tom
This appears to be a pressure issue instead of a temperature issue. If this is the only code present the EGT sensor shouldn't be involved.
I think.
Old Jul 28, 2011 | 12:10 PM
senix's Avatar
senix
I think.
I agree, just my gut says check it.
Old Jul 28, 2011 | 09:55 PM
silverandscout
error codes
thanks for all of your help and advise. It seems that there are several error codes being recieved, and that's why a Ford engineer has been called in. I'll let you know when I hear more.
Old Jul 29, 2011 | 09:41 AM
wp6529's Avatar
wp6529
Several error codes can point to an electrical issue such as a chaffed or melted wire that is shorting out a reference voltage used by multiple sensors. The diagnostic procedures in the service manual cover such faults, if they need to call in a Ford engineer rather than understand and follow those diagnostic procedures, I would be leery of using that dealer's techs in the future.
Old Jul 29, 2011 | 05:54 PM
silverandscout
error codes
Well we just got the truck back from the dealer. The Ford engineer found several connectors on the computer were corroded so they cleaned them (and I presume put some dielectric on). So you were right wp6529, sort of. I just can't believe the tech at the dealer didn't pull the connectors and look at them.
Thanks to all of you who offered advise.
Old Aug 1, 2011 | 10:21 AM
wp6529's Avatar
wp6529
Connectors are the biggest source of problems for all things electrical and electronic. Of course without connectors things become unservicable, so all you can do is try to use quality connectors and try to protect them.
BOLINJORDAN
Aug 14, 2009 08:17 PM
gentrykm
Jul 12, 2009 02:33 AM
tmrbiker
Sep 18, 2006 09:50 PM
4.9inline6
Jun 2, 2006 06:16 PM
t_dickie
Sep 19, 2005 11:13 AM
