6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
08 F250 - Weird Problems
Old Jul 30, 2011 | 02:12 PM
alexmartin33's Avatar
alexmartin33
Hi,
I am just looking to see if anyone on here has had similar problems with their truck as I have. My truck, like many other super duty's in the same year blows white smoke on an adnormal basis for me to still believe its the DPF. Recently, while it was raining out (not sure if that matters) my truck started, the air bag light stayed light and the wrench popped up and the truck studdard for about 15 seconds then ran fine.
Since this time my ABS light comes on at random then disappears. Both when the truck is cold and hot.
Today, I was driving the truck around town, pulled into a parking lot, put the truck in park and the same thing happened the air bag light came on and the truck started to shake. I shut the engine off, then tried to restart the truck and it would not fire. Once it wpuldnt start the truck light up "check brake system". I let it sit for 15 mins. Got back in and it started, ran for 10 seconds or so then quit. It finally did start long enough for me to move it out of the way, while moving the emergency brake light, ABS light and air bag light stayed lit and almost stalled. Once I stopped it did stall.
Funny enough, the truck sat for an hour. Hopped back in with a code reader and all of a sudden it started working and has since (only been 24hrs). No history codes were stored in the computer. The only other thing I noticed was an hour ago while driving, the truck wouldnt shift into third. It took a coupke of miles before it started to shift again.
Crazy and weird problems. Any suggestions. I tried ford twice and they couldnt find anything. They fixed the coolant twice to control the smoking but the coolant level is always low and always blows smoke. I am going to try a DPF anyway and see what that does.
Old Jul 30, 2011 | 05:09 PM
redford's Avatar
redford
FTE Leadership Emeritus
I think you have multiple problems there.
Low coolant, check head gaskets.
Shudder and engine dies.....you had a check engine light for a while, so you should have a code stored.
Old Jul 30, 2011 | 07:01 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.4L Powerstroke Diesel forum.
Old Jul 30, 2011 | 07:17 PM
senix's Avatar
senix
This is a whole bunch of things going on here. I am thinking the white smoke and coolant loss maybe EGR cooler related. Lends itself to the rough running issue as well.
Now as far as all the lights and stuff I think that is a wiring harness issue.
If you cannot seem to get anyway then I suggest you go to another dealer and let them have a go at it.
Also might want to rule out the obvious and have both batteries checked.
Old Jul 30, 2011 | 10:33 PM
StanleyZ's Avatar
StanleyZ
Justr courious, what do you mean you're going to try a DPF? Do you not have one? How many miles on the truck? Has it been tuned, if so what tunes? You surely have a couple different things going on.
Old Jul 31, 2011 | 11:20 AM
bushman134's Avatar
bushman134
There is a history of corroded connectors on sensors and the PCM might be the problem. That was what it was with mine
Old Aug 1, 2011 | 02:23 PM
alexmartin33
Thanks for the input. I might try going to another dealer. And as for the DPF, I have a DPF but I am thinking of getting the DPF delete package. Also the truck is not tuned.
Its been two days and nothing has gone wrong? The engine light never came on, just the wrench. The code reader I have does not detect any sotred codes. Not sure whats going on.
Old Aug 1, 2011 | 05:38 PM
cheezit's Avatar
cheezit
suspect cac needs to be updated.
check upper and lower hoise and left side tank for coolant leak if none found suspect leaking egr cooler
abs/airbag light possible failed shorted network concern. best guess is RCM going south.
user 6208924
Modular V8 (4.6L, 5.4L)
Jan 13, 2014 02:26 PM
dogman
Dec 7, 2011 05:10 PM
dogman
Dec 7, 2011 09:19 AM
bckhntr
Modular V10 (6.8l)
19
Oct 22, 2005 02:30 AM
custodian
1997 - 2003 F150
Jan 15, 2001 05:52 PM
