Engine Cool Down Feature (in conjunction with Remote Start)
Old Jul 26, 2011 | 03:15 PM
  #46
Hu Slung Pu's Avatar
Hu Slung Pu
Mine works, but I have to take the key out really fast or it doesn't. IMHO I think it's a Ford oversight/bug judging by how the engine does a quick hiccup and remains running after you pull the key out. My truck was built 10/10, not sure what Job number it is.
Old Jul 26, 2011 | 07:43 PM
  #47
trfield58's Avatar
trfield58
Just got mine to work too. Hard to tell but it's almost like the engine shuts of for a second but then continues to run again without the starter engaging. Very hard to explain but FINALLY got mine to work....
Old Jul 26, 2011 | 09:15 PM
  #48
cabindoc's Avatar
cabindoc
Yea, I am beginning to subscribe to the theory that this is a hiccup that the remote start was never designed to do this. Thats why folks are getting different results and there are different techniques that work. Hope everyone gets it to work, this is an awesome feature to have.
Old Jul 26, 2011 | 11:16 PM
  #49
Dr. T's Avatar
Dr. T
Got it to work once on mine. Have to really whip the key out quickly. 3/11 build. I really doubt this is a designed feature.
Old Jul 26, 2011 | 11:29 PM
  #50
goatram's Avatar
goatram
Mine Does not work; drats!
Old Jul 27, 2011 | 07:26 AM
  #51
6.7Fan's Avatar
6.7Fan
It's still odd that it seems to vary so much by individual truck; which probably leads to the theory that it is some sort of glitch. If I hadn't of read all of these on here, I would have thought it was designed that way based on how mine works. It really is as simple as the remote start and as reliable (for me). It's worked every time since I learned it from my996duc1.
Old Jul 27, 2011 | 09:08 AM
  #52
kper05's Avatar
kper05
So is this brief engine hickup good for it?
Old Jul 27, 2011 | 09:29 AM
  #53
Marauder92V's Avatar
Marauder92V
Ok. I'm done beating up my truck! I have tried, without success, to get this to work. I am officially in the NLECD club...
Old Jul 27, 2011 | 09:30 AM
  #54
Marauder92V
What is troubling is that NONE of the technical resources here have commented on this... None of the Ford techs have given us their thoughts...
Old Jul 27, 2011 | 09:55 AM
  #55
Rutcutter's Avatar
Rutcutter
My early Job 1 wont do it,all I get is two horn beeps.
Old Jul 27, 2011 | 10:05 AM
  #56
my996duc1's Avatar
my996duc1
I AGREE.
too bad this couldn't be sorted out and made into the next update computer flash.
Old Jul 27, 2011 | 10:13 AM
  #57
lkbrow1's Avatar
lkbrow1
I can't get mine to work.
2011 F350 DRW CC manufactured 4/30/11
Old Jul 27, 2011 | 11:49 AM
  #58
GZip's Avatar
GZip
Not having a truck yet, I can't test on my own, but this thread is interesting. When one does a remote start, does the engine crank immediately upon button push, or is there a delay? If one does a remote start while the engine is already running, does anything happen? If there is some sort of processing delay between button push and engine cranking, what is being seen here might just be a normal remote start where the correct conditions (engine off) are met quickly enough so that the process continues. That would explain the engine sputter as well.
Old Jul 27, 2011 | 11:59 AM
  #59
grantschim's Avatar
grantschim
There is a delay before the engine starts up, but you can hear the whining right before as the plugs warm up...then it starts up about 2 seconds later.
Old Jul 27, 2011 | 02:00 PM
  #60
GZip's Avatar
GZip
Does the delay time change if the motor is already warm? Also, does remote start work if the key is in the ignition?
