i just finished the egr delete, everything is back together but i am either short of fuel or air. the whole thing went together well but i cant build boost or climb above 2000rpm. any thoughts?
yes i just ran out and rechecked them and all others i could see. the only one that concerns me is in the very back against the up pipes i believe it is the icp
What year model is the truck? How long have you let it run since you put it back together? Did you disconnect the FICM when you loosened or removed the intake?
Check your FICM connections and make sure they snapped in and clicked. IMHO if you had that much trouble with air in the fuel then you might have pinched the primary filter cap o-ring and it's still getting air. Pull the secondary filter cap and see how quick it fills up with fuel when you cycle the key. It should be less than a second or so to fill it. If it takes longer than check the primary filter cap. It may or may not leak fuel but it will suck air.
secondary filter fills very quick and had no air bubbles. i'm used to 7.3L, is the hpop in the rear of the valley now and is that the icp under the up pipes?
ICP is in the passenger side valve cover on an 05. The IPR is under the turbo in the back and might be suspect also.
