Stupid panelling question
Old Jul 23, 2011 | 07:25 PM
ford2go's Avatar
ford2go
Hi,
I'm slowly redoing the insulation on the lower part of my basement walls ( The lower part projects out.)
Anyway, I put up some thicker insulation with 2x4s for holding the next layer of stuff.
I was going to put in some sheetrock, but I was in a hurry and just slapped up some 1/2" OSB. The insulation is rigid, but I didn't want the cats clawing it.
Anyway, I could take it down and put up sheetrock, but I thought that probably I could just panel over it.
Is there any good reason not to do it that way?
Thanks,
hj
Old Jul 23, 2011 | 08:09 PM
rollerstud98's Avatar
rollerstud98
What kind of paneling are you talking about? You can drywall right over it if thats what you mean. You won't have to worry about finding the studs to screw into doing that. If you are talking about those 4x8 foot sheets of fake wood paneling, I would recommend against that but its just my opinion that that stuff looks really cheap, always. Just like laminate floors.
Old Jul 23, 2011 | 08:30 PM
Eatonpcat's Avatar
Eatonpcat
No reason not to panel, other than in my opinion paneling is ugly!!! Let's see a picture of what you're thinking about installing
Old Jul 24, 2011 | 12:24 AM
Ford_Six's Avatar
Ford_Six
Does your local fire code allow paneling over OSB? Some of them now require the paneling to be on a fire-stopping surface, like sheetrock.
I wouldn't use paneling in a house after seeing how fast a trailer goes up-
Old Jul 24, 2011 | 06:37 AM
hanklin's Avatar
hanklin
how about this, sheetrock all of it then put up beadboard with chair railing on top of bb
Old Aug 3, 2011 | 08:52 PM
powerstroke F350's Avatar
powerstroke F350
sheetrock is cheaper than paneling but alot more work
Old Aug 4, 2011 | 12:49 AM
ford2go's Avatar
ford2go
I was hoping that someone might address that. I don't really see it as a problem in this case, but codes are codes.
The reason that I'm not worried is that its only half height, and, since it's in the basement, there's cement on the other side of the insulation. Plus, the upper part is sheetrock, and it's offset the width of a cement block.
hj
Old Aug 4, 2011 | 03:52 AM
Greywolf's Avatar
Greywolf
Nutz - I just discovered recently that I have a plywood ceiling in my den (the texture fell in spots) As fire hazards go - that ain't good for the annual PREMIUM is it?????
Old Aug 4, 2011 | 11:23 AM
Eatonpcat's Avatar
Eatonpcat
Don't tell the insurance company!!
ford2go
Aug 29, 2013 06:38 AM
smokewagun
13
Feb 5, 2012 10:18 PM
kpwall
Dec 14, 2006 04:52 PM
ranger rules
May 10, 2006 09:24 AM
horse_trader
Jan 30, 2006 09:20 PM
