1978 - 1996 Big Bronco
Whining under throttle
Old Jul 23, 2011 | 03:34 PM
redlineshifts's Avatar
redlineshifts
Just started today. While under partial throttle above ~35mph there is a noticeable whining noise. It seems to go away when just coasting and comes back under throttle.
Where should I start looking?
Old Jul 23, 2011 | 05:26 PM
Encho's Avatar
Encho
The Southernmost Mod
A dying belt or pulley maybe, or an empty/leaking steering pump reservoir.
Old Jul 25, 2011 | 10:06 AM
Kemicalburns's Avatar
Kemicalburns
pop the hood and have someone rev the motor in neutral and see where its coming from. the stock ford pumps are known to whine, the belt tension pully should be more of a chirp but could whine i suppose if the pully was wearing out.
I would start with a new belt if its old.
Old Jul 25, 2011 | 07:42 PM
g_k50's Avatar
g_k50
air inlet makes some noise, I would check the air filter, did you just change it?
devrcracer
1997 - 2003 F150
Apr 27, 2015 07:26 PM
1badCTS
Aug 27, 2012 09:49 PM
rockcrawler_101
Jan 31, 2010 10:28 AM
CounterMaker
Jul 5, 2007 07:12 PM
Mr. Fixit
Apr 8, 2005 06:48 PM
