stupid drums!
Old Jul 22, 2011 | 10:56 PM
Onus's Avatar
Onus
stupid drums!
The driver side drum decided to seize up. Got a nice smoke show from that when i stopped at my friends house. I guess i shouldn't use the e brake on these trucks (don't like just using the parking prawl on the transmission), it seems to not really like to work well. Anyway i got the brake unseized, it wasn't smoking when i got home, and the annoying squeaking noise is gone (reason i look in the first place, it's dark and can't see anything, also it took more power to get the truck moving).
Would love to put in a sd rear axle with the nice disk, and drum in hat brakes. Now since its 2wd i'd have missmatching wheels, i doubt the i beams are swappable.
Old Jul 23, 2011 | 06:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have never used a cable parking brake in all the 40 years i have been driving. the one time my ex used the parking brake in the 79 back in 84 it locked up the rear brakes and i had to cut the cables to release them.
Old Jul 23, 2011 | 08:15 AM
monte97z's Avatar
monte97z
Ive never used the one in my truck, there is so much rust and the cables and spring Im convinced if i ever try and use it im gonna break something.
Old Jul 23, 2011 | 11:51 AM
Onus's Avatar
Onus
I been using it so everything works and it doesn't get seized up but, so much for that. Not using it right now. Drove across the state on the highway its not seized.
Old Jul 23, 2011 | 01:21 PM
Country_boy_2007's Avatar
Country_boy_2007
i use mine all the time in my 88 5 speed, its something that you need to use every day, or never at all
Old Jul 23, 2011 | 08:05 PM
Onus's Avatar
Onus
I figure i'll keep using it. I've been using it since i got the truck so i might as well continue at this point. I can pretty much tell now when the brakes are seized up.
Anyone happen to know how to adjust the ebrake. The pedal in the cab doesn't retract the extra centimeter to turn the dang light of in cab.
Old Jul 23, 2011 | 08:17 PM
tjc transport
i ain't rite
under the driver seat on the frame. i doubt if the adjuster will work though . you may have to add a spring to the pedal.
Old Jul 23, 2011 | 08:27 PM
ihateminimumwage's Avatar
ihateminimumwage
You'll want to wire brush the threads on the cable adjuster and soak with PB Blaster like crazy before trying to tighten it.
If your axle is a 10.25, disc conversions aren't that expensive to do. Probably cheaper than trying to refurbish and install a later model junkyard axle.
Old Jul 24, 2011 | 06:56 AM
Onus's Avatar
Onus
I have the brackets to put e series rotors with chevy 3/4 ton front calipers from ruff stuff. I was gonna use it on the plow truck.
Old Jul 24, 2011 | 01:37 PM
oreocreaming's Avatar
oreocreaming
i used mine and it froze in the cable. just took some bolt cutters to the cable right before it goes into the drum and it cleaned right up.
kmacht
May 10, 2020 06:14 PM
FBNengr
Large Truck
Feb 22, 2011 08:53 AM
CooGAR
Feb 2, 2011 11:03 AM
gary_b
Oct 16, 2006 07:46 AM
51fordrodder
Apr 24, 2005 06:15 AM
