Engine Build help
Old Jul 22, 2011 | 10:24 AM
pitbull357mag's Avatar
pitbull357mag
Engine Build help
I have a 75 302 marine I belive it is a HO it has the 351 firing order. I am switching it over to put in my 82 F100 short bed so I'm needing help building it. My grandfather said I would need a new distributor, flex plate bolts (because the motor has studs), exhaust bolts( because of long studs), and carburator. I'm thinking about these parts, what is you opinion on these and what else do I need to do to switch it. There is 2 intake manifolds I am looking at one is a stage 2 Summit Racing without a rear water crossover and the other is a stage 3 Summit Racing with a rear water crossover which one do I need? I'm looking a Lunati 280 bare bones 351w cam or can I go bigger with out modding the heads. Some one told me if I went too big I would have to get spacers to rise the heads up or it could cause the valves to hit the pistons. And also I'm looking at a set of aluminum GT40 EFI heads will these work on a 75??? This is just a start on what I'm thinking about but this is my first engine build any help or advise would be awsome.
Old Jul 22, 2011 | 10:31 AM
Conanski's Avatar
Conanski
A marine engine should already have GT40 heads on it, best thing to do is get the casting numbers off them(they're on the head gasket side) and post them up and then we'll see.
What type of use will your truck see with this motor? A 5.0 can produce great HP but it's a little weak at low rpms so it isn't the best platform for a relatively heavy truck without axle gearing and/or a high stall converter.
Old Jul 23, 2011 | 08:35 AM
pitbull357mag
It's mainly a daily driver I do not pull or haul anything. I was going to lower it and turn it to a show truck.
Old Jul 23, 2011 | 04:03 PM
Conanski's Avatar
Conanski
The 302 will do just fine then, post up some casting numbers and we'll go from there.
Old Jul 27, 2011 | 09:52 AM
mark a.'s Avatar
mark a.
I would be very leery about using a marine engine in a vehicle. Lots & lots of them have cracked blocks & maybe even a head or something else and will leak coolant when put into a pressurized system. Look it over VERY closely.
Cburks
Dec 16, 2016 09:54 AM
Buyerz
Jun 19, 2016 09:45 AM
mroseboom10
May 21, 2015 02:05 AM
Feardeere7
Mar 5, 2015 04:59 PM
rsylvstr
Exhaust Systems
18
Aug 18, 2007 07:55 PM
