grrrr coolant question
Old Jul 22, 2011 | 08:33 AM
noshow's Avatar
noshow
diesel stop guy listed walmarts supertech as a recommendation. he also states that ford hasnt approved the use of elc or coolants that can be mixed with any color of antifreezes. The supertech coolant says it can be mixed with any color coolant and it also says it is "LONG LIFE", my question is, is there a difference in long life and extended life..........? and more importantly, can I use the supertech coolant? NOTE: I have the motorcraft sca
Old Jul 22, 2011 | 08:55 AM
Talyn's Avatar
Talyn
I woudldn't mix different colors.
Few guys on here are using that gold stuff. Not sure about it.
I'm going to be in that boat here in a few days. Maybe tomorrow.
Do not forget anti cavatation additive.
Old Jul 22, 2011 | 08:59 AM
noshow's Avatar
noshow
im not mixing any of them. drained and flushed system and I allready have the sca (anti-cavitation additive) just need to know if I can use the supertech of not because its contradicting as per my first post.
Old Jul 22, 2011 | 09:45 AM
makomark's Avatar
makomark
Read the label on the jug of SuperTech. Pretty sure the factory recommendation says use only a low-silicate ethylene glycol-based coolant (ASTM D-4895). Ford does not recommend using propylene glycol coolants in any of their vehicles.
As long as the Supertech says it meets ASTM D-4895, you will be fine. Don't forget to add the correct amount of SCA and then check it after a few drive cycles.
Old Jul 22, 2011 | 11:23 AM
Talyn's Avatar
Talyn
nice info mark.
gtm245
Oil & Lubrication
22
Sep 10, 2017 04:02 PM
Milwaukee1979F150
Jul 6, 2012 08:27 AM
Iowa F-150
2004 - 2008 F150
16
Feb 13, 2011 05:10 PM
ford390gashog
Oil & Lubrication
Jul 4, 2004 02:44 PM
gtm245
Oil & Lubrication
19
Mar 24, 2004 06:28 PM
