oasis report
Old Jul 20, 2011 | 05:16 PM
the almighty schmuck's Avatar
oasis report
passed by the dealer today and got an oasis report on my truck. just got it a week ago with 105k on it and 5 years old so i figured any work done to the truck is most likely warranty. it turns out its been to the dealer once for 2 problems an oil leak and replace the hpop. i have a few questions maybe yall can answer
1-this work was done in dec 2009 and says stc replacement. is that late enough to get the upgragded fitting or is this the same one that will go out again?
2-what is pid data test?
3-what is cont test?
4-what is koeo test and koeo injector test?
5 what is a bed plate?
thanks in advance
Old Jul 23, 2011 | 10:43 PM
i figured out what koeo is. anybody have a qlue as to the rest?
Old Jul 23, 2011 | 11:16 PM
cheezit's Avatar
cheezit
oasis should list the part number installed. varify with that what part was used. pid data is the information showen by the pcm and is used to help detremin what is wrong with the truck. cont test is a test to see what codes are stored aka cmdtc's.
koeo key on engine off.
injector test is a self test of the injectors electrial functions done with a scan tool
bed plate is the lower portion of the main engine block.
Old Jul 23, 2011 | 11:35 PM
m-chan68's Avatar
m-chan68
PID = Parameter Identification Data.
A cylinder contribution test is a test that monitors the firing strength of all cylinders. In plain English, a test to ensure all cylinders are pulling their weight so to speak.
KOEO = Key-On/Engine-Off (as you've already figured out) KOEO On-Demand Self tests checks all circuits to all sensor inputs/outputs. A KOEO Injector test is a test that checks the integrity of all electrical circuits between the FICM and injectors. It DOES NOT pinpoint mechanically faulty injectors.
A bed plate is the lower half of the engine block. It is the main crankshaft support on a 6.0L/6.4L diesel engine.
thanks in advance
The highlights in bold red should clearly answer your questions.
Old Jul 24, 2011 | 12:04 AM
thanks guys. thereis no listing of part numbers though
scarty111
Sep 1, 2013 12:38 PM
RIKIL
Mar 9, 2013 01:43 PM
p8ntballn2
Feb 14, 2011 10:22 PM
EatBeef
Sep 29, 2009 06:58 PM
jetpilot2
Sep 16, 2009 08:26 PM
