352 FE timing
Old Jan 4, 2015 | 03:09 AM
northdakota 67ford's Avatar
northdakota 67ford
352 FE timing
so im putting in a new distributor and i have to do the time ignition timing from scratch. this new distributor is electronic ign. anyways i was wondering how u no where to put distributor from scratch.i dont really mess with distributors. excpet on old motorcycles. but anyways so do i just get the number 1 cylinder to tdc on compression stroke and have the rotor underneath the number one spark plug wire on distributor.
Old Jan 4, 2015 | 03:28 AM
51M1's Avatar
51M1
Pretty much thats it. At TDC #1 on cap towards the front of motor when distributor is fully seated. If the motor doesn't fire and you have good spark you might be 180 degrees out on the timing. Swap all the plug wires 180 degrees on the cap. Swap wires with the wire on the opposite side without removing the dist. Then try starting again.
Old Jan 4, 2015 | 09:27 AM
HIO Silver's Avatar
HIO Silver
Here is an article from my friends at CarCraft: How to Install a New Distributor - Car Craft Magazine
Muidem
32
Jun 21, 2011 04:46 PM
dogmantra
Oct 4, 2010 12:43 AM
Bovaloe
Feb 17, 2010 10:33 PM
btacarlton
28
Apr 17, 2009 09:40 AM
teachcool
Jan 4, 2003 06:41 PM
