Blown Axle Seal?
Jul 19, 2011 | 09:16 PM
9 ECHO 1
Blown Axle Seal?
Do I need to fix this? My intuition says yes. If so, what do I need to do?
I'm doing the hub and needle bearing work soon so I'll do it at the same time.
Jul 19, 2011 | 09:31 PM
Inner axle seal. Since your going to have the diff apart you may as well do both sides.
Jul 19, 2011 | 09:32 PM
9 ECHO 1
Quote:
Originally Posted by
Ricohman
This is very annoying. I JUST changed my differential fluid. Anything else I should do while I'm in there?
What part do I need?
Any write ups?
Jul 19, 2011 | 10:26 PM
Jul 19, 2011 | 10:31 PM
You may also need a case spreader but a few pieces of wood and a pry bar may also work. Don't drop the carrier on yourself.
Jul 19, 2011 | 11:13 PM
9 ECHO 1
Anyone got a link to the tool? This is becoming a pain..
Will I have to drain and refill my diff fluid?
Jul 19, 2011 | 11:17 PM
Jul 19, 2011 | 11:19 PM
TreySpooner65
mueckster
For model 50 axles, use special tools 205-428, 205-425 (LH), and 205-424 (RH) to install the axle shaft oil seals.
For model 60 axles, use special tools 205-428, 205-427 (LH), and 205-426 (RH) to install the axle shaft oil seals
From my manual. 205-424,425,426,427 are the stepped plates for the seals. 205-428 is the threaded bar.
Gonna have to try the local auto parts tomorrow looks like! Good luck man, that sux, I hate special tools!
Jul 19, 2011 | 11:22 PM
9 ECHO 1
Why the heck is this so confusing lol. No one that sells them just says "HERE THIS IS WHAT YOU NEED"
Blah specialty tools
EDIT: I found what I need. About $130 from that 4x4tools.
Jul 20, 2011 | 07:02 AM
Jul 20, 2011 | 10:32 AM
SGnAZ
That's only for the outer axle seal but you still need a tool for the inner seals in the differential housing.
Jul 20, 2011 | 11:43 AM
Looking at the pic below I think you could make one somewhat cheaply.
Here is a crude drawing of how it might be able to be made. No idea if it will work but it's an idea.
VitaminC
93
Nov 8, 2019 12:25 PM
bb65f1004x4
Jun 6, 2016 12:52 PM
Johnny L
41
Mar 17, 2015 04:38 PM
TCAS007
2009 - 2014 F150
20
Feb 24, 2014 12:52 PM
69SCJ
15
Jul 30, 2012 08:49 PM
1999 ,
2000 ,
4643 ,
50 ,
axel ,
axle ,
blown ,
dana ,
escape ,
f250 ,
ford ,
installer ,
manual ,
seal ,
seals ,
service ,
tool ,
ts4643 ,
tsb
